Re: Best place to plumb an oil accumulator?
[Re: BradH]
#1079779
09/21/11 01:48 PM
09/21/11 01:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I guess I'm interested in knowing whether one of those locations would be consdered more "proactive" vs. "reactive" w/ respect to handling the situation when the oil pickup is uncovered.
If I understand the path of the oil system correctly (that's a BIG "if" ), wouldn't it make more sense to ensure the flow of oil right above the pump isn't interrupted, rather than introducing the additional oil at the rear of the block after the lack of oil to the mains & rods would have happened?
One thing you dont want to do is use the oil sending unit hole... thats 1/8 pipe and wouldnt be enough supply if you did loose pressure
[Re: HEMIFRED]
#1079782
09/21/11 09:24 PM
09/21/11 09:24 PM
Posts: 903 Saskatchewan, Canada
cudabin
I used the sandwich adapter with the #10 line. this allows for seamless oil supply if required. The smaller 1/8 lines won't save your motor if the pickup runs dry or the oil pump quits...
Good luck,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: HEMIFRED]
#1079787
09/22/11 10:40 AM
09/22/11 10:40 AM
BradH
SIZE DOES MATTER
Shhhh!!! I don't want my wife to know that...
Oh, so back the oil accumulator questions.
