What is the best cleaner for a white vinyl interior? #1079663
09/21/11 07:56 AM
09/21/11 07:56 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Hello, I have a customers car and it has a white vinyl interior and it is dirty. I tryed 409 cleaner but it didn';t clean it. What is a good deep cleaner to bring back the "White" color so it doesn't look so dirty?
Re: What is the best cleaner for a white vinyl interior? [Re: GLR] #1079664
09/21/11 08:28 AM
09/21/11 08:28 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I always used Whestleys bleach white and a bristle brush with excellant results
Re: What is the best cleaner for a white vinyl interior? [Re: GLR] #1079665
09/21/11 08:47 AM
09/21/11 08:47 AM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
Try using Meguiar's Heavy Duty Vinyl Cleaner. I bought some after getting caught in a rain/windstorm at a gas station one year at Carlisle. The wind/rain blew dirt & grease from the tops of the gas pumps all over my white vinyl top. It was literally disgusting. I went back to the fairgrounds & bought some along with a bristle brush. It worked awesome on white!
You could also try Spray Nine. That also works great!
Re: What is the best cleaner for a white vinyl interior? [Re: bill440rt] #1079666
09/21/11 09:03 AM
09/21/11 09:03 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Cool! Thank you!
Re: What is the best cleaner for a white vinyl interior? [Re: GLR] #1079667
09/21/11 09:16 AM
09/21/11 09:16 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
get some RAM cleaner.
Re: What is the best cleaner for a white vinyl interior? [Re: bonefish] #1079668
09/21/11 09:53 AM
09/21/11 09:53 AM
My hovercraft is full of eels
DaveKanofsky Offline
As funny as it sounds, try the Mr. Clean magic eraser.
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
Re: What is the best cleaner for a white vinyl interior? [Re: DaveKanofsky] #1079669
09/21/11 09:56 AM
09/21/11 09:56 AM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
Spray 9 worked the best for me on vinyl interior
Switched to the dark side...
Re: What is the best cleaner for a white vinyl interior? [Re: DaveKanofsky] #1079670
09/21/11 09:57 AM
09/21/11 09:57 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Those things have mystical powers.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: What is the best cleaner for a white vinyl interior? [Re: JSR1485] #1079671
09/21/11 11:38 AM
09/21/11 11:38 AM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Re: What is the best cleaner for a white vinyl interior? [Re: DaveKanofsky] #1079672
09/21/11 11:46 AM
09/21/11 11:46 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Yep, that is the trick. Gets grime out of the grain of the vinyl. For some extra strengh use a little 409 along with them but typically you just use water.
Re: What is the best cleaner for a white vinyl interior? [Re: NicksGarage] #1079673
09/21/11 12:22 PM
09/21/11 12:22 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Spray Nine, Liquid Zud and Magic Eraser are the ones I used with success
Re: What is the best cleaner for a white vinyl interior? [Re: mopars4ever] #1079674
09/21/11 12:26 PM
09/21/11 12:26 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Comet and a green scotchbrite pad works the best for me for the toughest stains in my white interior. If it's just regular dirt the mr clean magic erasers do okay but for the deep down aged in filth I have better results with comet.
Re: What is the best cleaner for a white vinyl interior? [Re: DaytonaTurbo] #1079675
09/21/11 12:45 PM
09/21/11 12:45 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Well, I bougt some of the Meguiar's Heavy Duty Vinyl Cleaner, I didn't think it was going to work at first, but I found that if I sprayed the seat and scrubbed it with a soft brush that it works pretty good.
Thanks alot!
Re: What is the best cleaner for a white vinyl interior? [Re: GLR] #1079676
09/30/11 03:04 PM
09/30/11 03:04 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I was frustrated with a 35 year old vinyl roof with a grain. Tried everything.
What worked for me:
1. SOAK w/vinyl cleaner (Tutle Wax, Meguiers,etc)
2. Rub in cleaner with Mr. Clean Magic Sponge
3. Get into smallest pores with 0000 steel wool lightly
4. Rinse w/clean water and very little detergent.
I do not not know if you can see the difference in the pic but it is dramatic in person.
Re: What is the best cleaner for a white vinyl interior? [Re: Commando1] #1079677
09/30/11 10:10 PM
09/30/11 10:10 PM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
I've used hand soap like the permatex brand in the past to clean white interiors. I spent 12 years working in a detail shop. I figure if it's safe enough to use on your hands then it's safe enough for vinyl seats.
Re: What is the best cleaner for a white vinyl interior? [Re: rallye73] #1079678
10/01/11 09:13 PM
10/01/11 09:13 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
a detailer i knew would use ATF on the nastiest vinyl roofs then buff it out---dont know it would try that on the insides of a car though---bob
Re: What is the best cleaner for a white vinyl interior? [Re: GLR] #1079679
10/01/11 10:30 PM
10/01/11 10:30 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
We picked up a 73 Charger years ago that had a filthy white vinyl interior. I pulled the buckets out and my wife got out the Simple Green with a soft brush and it worked very well. If the Magic Eraser would have been around back then I would have probably tried that too but the SG did the job and the seats and panels looked like new when done.
Old, tired, and sometimes broke down. Me, not my car...
