What newer radiator will fit in a 1947 Dodge WC pickup? #1079646
09/21/11 05:01 AM
09/21/11 05:01 AM
MN
Skid_Demon Offline OP
MN
I am thinking of replacing the stock radiator with a newer (60's or 70's) to help keep the 360 cooler. The stock one has a zero to 4 psi cap, so it doesn't take much on a 90 degree day to get it cookin. Any info would be helpful. Thanks.
Re: What newer radiator will fit in a 1947 Dodge WC pickup? [Re: Skid_Demon] #1079647
09/21/11 10:05 AM
09/21/11 10:05 AM
E
earlymopar Offline
earlymopar  Offline
E
One of the more inexpensive swaps is to use a mid 60s, 289-302 factory (OEM) Mustang radiator. You can go to any NAPA store and get them for $140 or so. The other option is an aluminum aftermarket radiator. At least there are cheaper models being made now for vertical flow radiators (like your stock unit). For many years the only inexpensine aluminum radiaots were for cross-flow systems.
Re: What newer radiator will fit in a 1947 Dodge WC pickup? [Re: earlymopar] #1079648
09/21/11 11:55 AM
09/21/11 11:55 AM
NE Iowa
Road_RunnerSteve Offline
NE Iowa
Champion Radiators now makes an Aluminum Radiator just for these trucks. My dad provided them with the stock '40 radiator that they patterned it after.
Brent Landess with Kool Radiators distributes them. I'm not sure of the price.
Re: What newer radiator will fit in a 1947 Dodge WC pickup? [Re: Road_RunnerSteve] #1079649
09/21/11 12:26 PM
09/21/11 12:26 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Those radiators are $350 on eBay. I measured and a a body will fit work on truck that has been clipped.
Re: What newer radiator will fit in a 1947 Dodge WC pickup? [Re: Skid_Demon] #1079650
09/24/11 09:38 AM
09/24/11 09:38 AM
MN
MN
Not sure what clipped means. I need a radiator about 19 inches wide. I believe the V8 A body radiator is 22 inches wide. Thanks for the ideas though.
Re: What newer radiator will fit in a 1947 Dodge WC pickup? [Re: Skid_Demon] #1079651
09/24/11 07:59 PM
09/24/11 07:59 PM
dogdays Offline
dogdays  Offline
I think the special "dartsportsteve" radiators are $350 on the 'bay per the next poster.
Looks like a decent way to go.
R.
Re: What newer radiator will fit in a 1947 Dodge WC pickup? [Re: dogdays] #1079652
11/11/11 10:18 PM
11/11/11 10:18 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
cheapest aluminum are the generic sold by speedway---they are a crossflow but my hotrod pals stand them up and use a hose filler coupling---speedway is the biggest circletrack supplier and those guys crunch radiators all the time---bob
