water spots #1079480
09/20/11 09:54 PM
09/20/11 09:54 PM
Virginia's Eastern Shore
dmoore Offline OP
dmoore  Offline OP
How do you guys removed hard water spots from your glass, windshield,back, side etc....
Re: water spots [Re: dmoore] #1079481
09/20/11 10:22 PM
09/20/11 10:22 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
if it's real bad, i would try CLR or lime away. and don't spray it all over the car. try in a small spot on the glass first. just spray some on a paper towel, wipe a spot then dry with a clean towel. after use Windex.
or you could try straight ammonia first.
Re: water spots [Re: dmoore] #1079482
09/21/11 10:36 PM
09/21/11 10:36 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My water is especially full of calcium crud. Wiping off the drops before they dry with my wife's bath towels works good.
