3461187 master cylinder for 71 Cuda. Work in a 70? #1079454
09/20/11 09:18 PM
09/20/11 09:18 PM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
I have a master cylinder #3461187 which is listed as correct for 71-up Cudas. Do any of you brake guys know if this would work in a 70 Cuda?
Re: 3461187 master cylinder for 71 Cuda. Work in a 70? [Re: Mike H] #1079455
09/20/11 10:49 PM
09/20/11 10:49 PM
If you have manual brakes then it must have the shallow groove part way inside the rear piston as opposed to a smooth tapered barrel like the inside of a thimble. If PB you're good either way
