Another vert question: Top frame #107800
08/20/08 02:17 PM
08/20/08 02:17 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
I have the top frame, to my 67 coronet vert, apart for paint.. Both of the side pieces ( the folding apparatus) are very tight and difficult to operate by hand.. Bead blasting and painting right now, so I do not want to spray any lube into the joints and hinge areas..
My question is should these work very easily?? And if they should any help out there with lubing these or making them work again?? Thanks
Re: Another vert question: Top frame [Re: minivan] #107801
08/20/08 04:37 PM
08/20/08 04:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've done quite a few, they are somewhat tight until you spay some penatrating lube in them...Obviously wait till they have been painted or powdercoated then a little lube & all will be good...
Re: Another vert question: Top frame [Re: 1_WILD_RT] #107802
08/20/08 09:14 PM
08/20/08 09:14 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Thanks.. Trying to fold up one now to get it in the bead blaster...
Re: Another vert question: Top frame [Re: minivan] #107803
08/21/08 08:54 PM
08/21/08 08:54 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
bolt it to the body so it's well supported, then push rearward on the pivot point by the rear window while lifting at the front...If you just lift it will bind...
