Re: Car starts when key is RELEASED, why? * UPDATE*
[Re: Strawdawg]
#1077574
10/22/11 12:56 PM
10/22/11 12:56 PM
Posts: 3,663 The Historic Hudson Valley
MONC
THanks Steve, yeah it's a good feeling. Just started it again after sitting ,and started right up and idled well, sounds good. Going to have to go drive it and see what happens now. Hopefully it won't cut out.
[Re: RapidRobert]
#1077576
10/22/11 01:47 PM
10/22/11 01:47 PM
Posts: 10,214 Someplace you aren't
SomeCarGuy
This is exactly why I ALWAYS ground the ECU. You will get weird things going on when they have intermitent ground. I've put "bad" ECU's back on for people and they work with a good ground. Glad you got it going.
I want my fair share
[Re: SomeCarGuy]
#1077577
10/22/11 02:25 PM
10/22/11 02:25 PM
Posts: 1,012 indiana
mcmopars
indiana
well here you go.mine will do what yours does.when it acts up and wont start,i get out and unplug the ballast,reconnect,and she fires.figure that out?i have not.it will be ok for well maybe 1/2 a season then do it again.
[Re: Strawdawg]
#1077579
10/22/11 03:53 PM
10/22/11 03:53 PM
mcmopars
indiana
You might try disconnecting it, shining up the terminals...put a dab of dielectric grease...or even plain grease on....and then reconnect. Wait half a season and see if it does it aain
nope
[Re: Strawdawg]
#1077581
10/22/11 08:20 PM
10/22/11 08:20 PM
mcmopars
indiana
You're right...no need trying to fix it when you can just wait til it does not start and replug it [/
im trying to fix it,ive done your idea years ago
[Re: mcmopars]
#1077582
10/23/11 12:34 AM
10/23/11 12:34 AM
SomeCarGuy
I'd say you have a bad crimp on one of the ballast wires and you reconnect the wire and get it back to where it makes good contact.
[Re: SomeCarGuy]
#1077583
11/05/11 02:20 PM
11/05/11 02:20 PM
MONC
Well, after many weeks and one hell of a snowstorm, finally took the car out for a ride to see if it the stalling issue was fixed. The car ran pretty well, and I was finally able to get it inspected. Couple of side notes, I had no brake lights when they went to check them, I knocked off the brake light switch while working under the dash for so long , DOH ! On the way back just as I was approaching home, I thought I heard the rear whining a little. Not sure if that was due to the cold weather or not. Regardless, the car is safe back at home, thanks again for everyone's help
