Re: This one is for the six pack experts
[Re: Sixpak]
#1076925
09/18/11 10:47 AM
09/18/11 10:47 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
Do the accelerator pumps work on the end carbs? The mechanical linkage effectively overrides the vacuum diaphragms functioning. If those are original vacuum secondary carbs then someone has done some serious modifications to them to use an accelerator pump. What are the list numbers on the carbs?
I agree with this , I've never seen outboards with vacuum pots AND accelerator pods other than there was a company in Georgia for a short time that was modifying end carbs and adding accel pumps, I also notice there are no metering blocks , are those end carbs off a BB vette ????
[Re: JohnRR]
#1076934
09/19/11 01:00 PM
09/19/11 01:00 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
With mechanical linkage shouldn't the outer vac pots be disconnected from the linkage ???
They don't matter since they will never over come the mechanical linkage.
[Re: Morty426]
#1076935
09/19/11 09:45 PM
09/19/11 09:45 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
I just like this icon
[Re: RoadRunnerJD]
#1076936
09/20/11 01:13 PM
09/20/11 01:13 PM
Morty426
Sacramento CA
So do I - I just wish it didn't hit home so much
