Re: factory 440 compression heights [Re: 446acuda] #1076876
09/19/11 09:24 PM
09/19/11 09:24 PM
junction city oregon
V
viperblue72 Offline OP
V
I contacted ronp and he sold those already. I am actually very undecided on what to do. I do plan to do something to raise compression be it use std. Pistons, have it bored, or smaller chambered heads. I may still just use a ridge reamer as I don't want to spend much. This is an 1500 dollar truck that's just gonna get abused severely.
Re: factory 440 compression heights [Re: viperblue72] #1076877
09/20/11 06:09 AM
09/20/11 06:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How many miles on that block? Do you have the skill to use the ridge reamer properly ? I had a 440 that someone took a ridge reamer to , had to sleeve one hole because it had to be bored .075 over to clean up the mess. even after you remove the ridge you might still have a step , I have a low mile rebuilt 440 here that was rehoned , it has a 1/4 moon shaped spot on the thrust side on I think all cylinders that the hone didn't touch. If i changed it to taller pistons I'm sure it would be breaking rings.
Re: factory 440 compression heights [Re: JohnRR] #1076878
09/20/11 12:49 PM
09/20/11 12:49 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
You don't need pistons to beat the hell out of a $1500 truck.
I went 12 flat with a 77 440 and a .528 cam in a 3650# 64 dodge.
Its all in the tune up, not pistons.
