Page 5 of 11 1 2 3 4 5 6 7 10 11
Re: Post your custom front disc brake setups. [Re: Dave440] #1076454
09/18/11 04:35 PM
09/18/11 04:35 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I gotta say FEETS I usually dont like modern rims on older cars...esp oversize rims...but that combination absolutely ROCKS!! Its like those rims were made for the car and the tires fill up the wheel wells perfectly! Gotta say... Ive heard of using Viper, Cadillac, GM and other assorted disc brakes but Mercedes? I swear...Just when I think ive seen everything there is to see... And OZ ...super job on those brackets!!
They were made for the car actually...they are a one-off casting to fit the brake setup he has.
The wheels I use were designed for road racing Porsches originally, and the style of outer they use has a special narrow drop area to give more caliper clearance actually. I could still go slighter larger in diameter with the rotor even and still have room. And even though the 4 piston Brembo are plenty I would say...if the situation does come up and fall upon some 8 piston AMG calipers..I'll just whitte up some new brackets and go with them.
Re: Post your custom front disc brake setups. [Re: feets] #1076455
09/18/11 04:36 PM
09/18/11 04:36 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Oz, that car belongs on the cover of Pimp My Tostito magazine.
Just was working on it today some actually..the fuel gauge has never really been "right" since I built it so switched over to a different style sending unit and just trying to dial it in.
Re: Post your custom front disc brake setups. [Re: OzHemi] #1076456
09/18/11 06:40 PM
09/18/11 06:40 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
For those not looking to get quite a wild as Feets & Oz another option is late model Mustang GT or Cobra brakes... I'm using the cheaper GT brakes on my station wagon, they are 12.8" rotors & two piston calipers which I found as new take-offs from Saleen, I got the rotors, calipers, brackets, pads, hoses, & hardware all for $149.00 plus $25 shipping... similar adapting & they are ready to run..... Not nearly as cool looking as the big AMG brakes but a huge improvement of stock & stupidly cheap.....
Re: Post your custom front disc brake setups. [Re: 1_WILD_RT] #1076457
09/18/11 06:51 PM
09/18/11 06:51 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
The 14.2" rotors are only like $170 ? or so right from Mercedes by the way..
Not as cheap as the setup you have..but still a heck of a deal for what they are I think.
I've got a pair of brand new PBR twin piston calipers here too actually..they (along with some off the shelf adapters from Oz I have) bolt right onto the Aussie Mopar spindles
When I have nothing to do, just have to find a rotor to fit it..they use a 2 piece rotor/hub setup so having just the hubs to mount larger rotors on is only knocking-out-the-wheel-studs away.
Re: Post your custom front disc brake setups. [Re: OzHemi] #1076458
09/18/11 07:04 PM
09/18/11 07:04 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
$170 for the pair? Or each? Either way I'm not saying there's anything wrong with going bigger just suggesting there are really inexpensive ways to greatly improve these old cars.... And yeah the calipers are PBR's, I'm sure they aren't of Brembo quality but I'll bet they stop better than the OE drums...
Re: Post your custom front disc brake setups. [Re: 1_WILD_RT] #1076459
09/18/11 07:09 PM
09/18/11 07:09 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Each
And the PBR ones are Aussie made, so nothing wrong there..
OE on Ford and GM here (and in Australia of course!)
I have a pair of brand new 13" drilled and slotted rotors around too...they are Holden Commodore ones, but too tall to work on my setup (push the caliper too far inward towards the control arm) but one of these days I will find something to do with them
(they might even work with the Valiant setup if I redrill them..haven't even measured them up yet..perhaps if using them mounted to the outside of the hub versus the inside like the factory Mopar ones mounted )
Re: Post your custom front disc brake setups. [Re: OzHemi] #1076460
09/18/11 07:21 PM
09/18/11 07:21 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Each
Damn, now my Wagon is gonna wind up upside down like your Charger....
Re: Post your custom front disc brake setups. [Re: 1_WILD_RT] #1076461
09/18/11 07:25 PM
09/18/11 07:25 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
That is ok...it makes it a closer match to the wagon my buddy here is building.... I got him an OHC OzFord inline 6 and overdrive auto trans for it.
Re: Post your custom front disc brake setups. [Re: OzHemi] #1076462
09/18/11 07:26 PM
09/18/11 07:26 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: Post your custom front disc brake setups. [Re: OzHemi] #1076463
09/18/11 08:39 PM
09/18/11 08:39 PM
detroit, mi
POS Dakota Offline OP
detroit, mi
That air cleaner...it looks perfect on it!
Re: Post your custom front disc brake setups. [Re: POS Dakota] #1076464
09/18/11 08:48 PM
09/18/11 08:48 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
The valve cover is just the stock one, so worked out cool with the aftermarket air cleaner assembly
Re: Post your custom front disc brake setups. [Re: feets] #1076465
09/18/11 08:52 PM
09/18/11 08:52 PM
detroit, mi
detroit, mi
POS, the AMG brakes I run might not fit 17" wheels. When mounted on my 18" Smoothie IIs I have really tight clearances. It's almost feeler gauge tight. However, these wheels have a raised runner in the back side of the drum that causes the issue.
Looking at the wheels you have now in the magazine article pics, I can see things are tight, but you're right. Might be that ridge. I'm currently waiting for my wheels to arrive in order to know what kind of room I am working with. I'm thinking 1/4 inch within the rim would be enough clearance given everything else is clear too.
It's just a waiting game for me now. I have the viper brackets I have to install on my rear axle, and then I have to acquire the calipers and rotors. This is just something I decided to do yesterday!
Re: Post your custom front disc brake setups. [Re: POS Dakota] #1076466
09/18/11 08:53 PM
09/18/11 08:53 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Don't worry...that is how alot of projects seem to happen..
Re: Post your custom front disc brake setups. [Re: OzHemi] #1076467
09/18/11 08:55 PM
09/18/11 08:55 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes it is....
Re: Post your custom front disc brake setups. [Re: 1_WILD_RT] #1076468
09/18/11 09:03 PM
09/18/11 09:03 PM
detroit, mi
detroit, mi
Yes it is....
It's the story of my life. I just decide to do something, get started so there is no turning back, then I sweat through the rest of it and figure it out.
Having that "incentive" to figure it out is usually everything I need!
A couple days ago I was going to install 11 inch drums, but I couldnt find the backing plates quickly and my mind wandered in the summit catalog for too long.
Re: Post your custom front disc brake setups. [Re: POS Dakota] #1076469
09/18/11 10:08 PM
09/18/11 10:08 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
That can get expensive..
Re: Post your custom front disc brake setups. [Re: OzHemi] #1076470
09/18/11 11:21 PM
09/18/11 11:21 PM
detroit, mi
detroit, mi
I'm not counting anymore.
Re: Post your custom front disc brake setups. [Re: POS Dakota] #1076471
09/19/11 12:12 AM
09/19/11 12:12 AM
detroit, mi
detroit, mi
These are nice pieces!
http://www.afcoracing.com/brakes_a_calipers.html
They can accomodate a 1.25 thick rotor.
Re: Post your custom front disc brake setups. [Re: POS Dakota] #1076472
09/19/11 12:27 AM
09/19/11 12:27 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Only an Inch and a quarter?
Wouldn't even fit over mine then
Re: Post your custom front disc brake setups. [Re: OzHemi] #1076473
09/19/11 06:52 AM
09/19/11 06:52 AM
detroit, mi
detroit, mi
Looks like once you get over that rotor thickness, they get really pricey from what I am seeing and they add another pair of pistons.
1.25 inch thickness seems to be very common in the aftemarket.
I think that would be the practical route for me to take...if I dare use that word to begin with.
