Page 1 of 4 1 2 3 4
Had To Have My New Crank Turned... UPDATE #1076196
09/17/11 12:12 AM
09/17/11 12:12 AM
MR_P_BODY Offline OP
I had mocked up my 416 with some old scuffed up bearings
(I didnt have the new bearings yet) and I felt a snug
spot in the couple of times I turned the crank...
I thought it was the old bearings... I put the new
bearings in and checked it again... it gets snug, so
I took it over to crank shop... well he called me today
to say the front is bent between #1 and #3 mains so
I asked if he could straighten it but he prefered to
cut it... its a new Scat/Mopar 4" that I've had for
a couple of years... it was .002 out .... I dont
know if I'll ever get this engine together... I should
have gone smaller and used my billet crank thats
just sitting around... that one is a 3.79 and I could
have off ground it
Re: Had To Have My New Crank Turned [Re: MR_P_BODY] #1076197
09/17/11 12:41 AM
09/17/11 12:41 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
That sucks...
Was it just a high spot out of round? You think he can just cut the high spot down, without cutting the other area of the same journal, or will he just turn the whole crank down some?
Re: Had To Have My New Crank Turned [Re: MR_P_BODY] #1076198
09/17/11 12:50 AM
09/17/11 12:50 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Sounds like yours might have come out of the same batch as mine. Mine had a tight spot, but was within factory spec for both clearance and run out. I used it as is with no problem, but it's a street motor. I probably would have turned it if I wouldn't have had the bearings already, or if I had racing aspirations.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Had To Have My New Crank Turned [Re: Bob_Coomer] #1076199
09/17/11 12:53 AM
09/17/11 12:53 AM
That sucks...
I just told him to cut it .010... so now I need a
set of new bearings... no big deal I have a few engines
with stock mains so I can use the bearings... I just
want this thing to spin freely
Re: Had To Have My New Crank Turned [Re: MR_P_BODY] #1076200
09/17/11 01:29 AM
09/17/11 01:29 AM
Cab_Burge Online work
Cab_Burge  Online Work
A good crank shop should be able to straighten it to get less than .001 run out Even if it is a cast crank
Re: Had To Have My New Crank Turned [Re: Bob_Coomer] #1076201
09/17/11 01:43 AM
09/17/11 01:43 AM
Delray beach, Florida
P
Performance Only Offline
P
That sucks...
doesn't sound like it's just a high spot. even if it was, you can't really grind just one spot on a journal.
Bob, did Brian ever get a hold of you on those heads?
machine shop owner and engine builder
Re: Had To Have My New Crank Turned [Re: Performance Only] #1076202
09/17/11 07:10 AM
09/17/11 07:10 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I have a 3.55 stroke MOPAR crank bought it out of a running engine. Just a couple passes on it. The guy must have dropped it because it is bent. It will not turn at all with all the main bearings in. Moldex said they could straighten it. happens all the time. Would not need turning at all.
Leon
Re: Had To Have My New Crank Turned [Re: MR_P_BODY] #1076203
09/17/11 08:48 AM
09/17/11 08:48 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Im quite sure you are having the whole assembly balanced...
I have an Eagle crank in my 499,,,everything was balanced and checked out except the flange...would you believe it was 150 thousandths to thick and caused the converter to eat the hardened pump drive...thought I had the clearance,..
good thing you caught it...
these cranks are Chinese forgings..aren't they suppose to be machined here?
Re: Had To Have My New Crank Turned [Re: MR_P_BODY] #1076204
09/17/11 09:08 AM
09/17/11 09:08 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Had similar problems with a brand new MP 4" steel crank a few years ago. It was .0005" too large AND .0005" out of round,,,,turned mains .011" to get true and oil clearance. It has been run for over 10 years now with no problems. Seems a shame to have to work on a new crank...especially AFTER all had been balanced. They offered to replace it,,but,,it had been balanced and I decided to keep it and repair it.
If you like drag racing, support your local track.
Re: Had To Have My New Crank Turned [Re: smokinwoody] #1076205
09/17/11 09:36 AM
09/17/11 09:36 AM
Yeah I already had it balanced... still no problem
with the balance... this work is being done to the
mains so that wont change
Re: Had To Have My New Crank Turned [Re: MR_P_BODY] #1076206
09/17/11 09:42 AM
09/17/11 09:42 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Well that sucks Mike, but sounds like you already took care of it. Wonder if it got dropped sometime before you got it, the way the front is off slightly it almost sounds like it got hit on the end.
Rich H.
Esse Quam Videri
Re: Had To Have My New Crank Turned [Re: ZIPPY] #1076207
09/17/11 09:49 AM
09/17/11 09:49 AM
I dont know... its never been dropped while I've owned
it and I got it new
Re: Had To Have My New Crank Turned [Re: smokinwoody] #1076208
09/17/11 10:02 AM
09/17/11 10:02 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Scat is machined here...Eagle, I dunno.
Re: Had To Have My New Crank Turned [Re: POS Dakota] #1076209
09/17/11 10:47 AM
09/17/11 10:47 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
Does this happen often w/ Scat cranks? I was going to order one today, until I read this.
Would I have better luck with a K1?
Kinda whizzes ya off, even if they are cheaper cranks.
Yeah, it's got a smallblock.
Re: Had To Have My New Crank Turned [Re: 340B5] #1076210
09/17/11 11:24 AM
09/17/11 11:24 AM
I cant say for fact... most of my SB stuff is 3.79
billet cranks... this is the first 4" forged stuff
that I have used
Re: Had To Have My New Crank Turned [Re: MR_P_BODY] #1076211
09/17/11 11:54 AM
09/17/11 11:54 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Sorry to hear that Mr P, Im really thinking that all these cranks are just the luck of the draw, like a water pump from a parts house most are right, some are not.
I just had a K1 that was out of spec and a scat that had to be exchanged in the past year.
People dog even eagle forged cranks, ive used to that checked out good, one has broken 4 mopar 4 speeds, 2 were liberty converted,the same crank made it through a nitrous issue, a hydrolock issue cought at startup and idle, and now has been hit with a 275 shot on a controller, and this last time apart magged fine and is still on the 3 year old calico coated bearings and spins like its on roller bearings.
Would I buy another eagle crank today...id have to think it over as there steel crank now seem to cost like the others, scat, K1 and I feel the overall chance of getting a better quality unit overall would be btter with scat or K1.
Ive been looking alot at the MP cranks going around for sale and have wondered for the lil extra cost thay ask for maybe the quality might be a bit better, but now I wonder and revert back to the luck of the draw thought.
I just popped for the very budget minded offset crank and older heavy pistons,oem rods listed on here for $200 bucks I thought id roll the dice in an old school build to see if kept under 6k and 500hp which will tell me if some of these $1500 cast stroker kits are just overpriced junk when the same can be acheived with almost oem parts.
Back to the MP cranks, the cost is more, and maybe yours did get dropped along the way prior to you getting it or just a glitched crank...
I wonder if and what some of these companies internal records would show on quality control issues during the whole process as well as the return/exchange failure rate, ect...
Anyways, sorry for the lil rant...you will get it sorted out, you always seem to fix every issue in short order
Re: Had To Have My New Crank Turned [Re: 340B5] #1076212
09/17/11 12:25 PM
09/17/11 12:25 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I'm of the opinion that scat cranks are pretty good pieces.
I've bought a cast 4 inch from them and also a forged 4 inch superlight which is a gorgeous piece for the money.
Both were well within spec. I agree with a previous gentleman's post regarding luck of the draw. To think there is ANY company that can keep tolerances we demand ALL THE TIME in mass produced stuff is impossible. Mistakes will be made and there will be inconsistency. You can't avoid it.
But in reality, this is NOT A PROBLEM within reason and is why we check things in the first place.
As far as brand goes...individuals often dont want to admit their high dollar piece came out of spec...I recommend asking a machinist since they look at a crank for what it is and not the logo etched on the weight, and it's their job to make it fit. They will likely give you a far more unbiased opinion.
Re: Had To Have My New Crank Turned [Re: POS Dakota] #1076213
09/17/11 02:56 PM
09/17/11 02:56 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
ALL Chinese cranks I use get drop shipped right to the crank grinder-then to my shop. I'd say that it's pretty common to have issues. 80% need some sort of rework. Part of the deal.
MB
Re: Had To Have My New Crank Turned [Re: HPMike] #1076214
09/17/11 04:00 PM
09/17/11 04:00 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
MB
All Chinese cranks should get drop kicked back to china,.... Just my opinion
Re: Had To Have My New Crank Turned [Re: emarine01] #1076215
09/17/11 04:45 PM
09/17/11 04:45 PM
MB
Yeah I got this crank a FEW years back... I didnt
know who made the cranks for MP... at one time Callies
made them for MP
Page 1 of 4 1 2 3 4
