Radiator Size #1073921
09/12/11 07:47 PM
09/12/11 07:47 PM
NY
Beep Beep Offline OP
NY
I am in the market for a radiator for my stock 383 RR. I am currently using the stock 26 inch rad with a front mounted a/c condenser for my factory A/C. I am in the process of building a 471 stroker that I am not sure if this rad will keep the engine cool. The current rad has been re cored to a 3row and it currently runs at 185f to 195f at 75f to 85f. Should I stick with this rad or upgrade?
Re: Radiator Size [Re: Beep Beep] #1073922
09/12/11 08:19 PM
09/12/11 08:19 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
3 core 26", yeah baby, thats good stuff but make sure you have a shroud!
Re: Radiator Size [Re: mikemee1331] #1073923
09/12/11 10:59 PM
09/12/11 10:59 PM
NY
NY
Yes I am using a shroud.
Re: Radiator Size [Re: Beep Beep] #1073924
09/13/11 10:52 AM
09/13/11 10:52 AM
3 core 26" w a shroud, yes you should b fine
