Dual feed 850 Holley vs Six Pack on a 440 #1072968
09/11/11 02:37 AM
09/11/11 02:37 AM
rtplumcrazy1 Offline OP
How does an 850 dual feed double pumper compare performance wise to a factory six pack set up. Consider that the 850 would have a good aluminum aftermarket intake. The 850's i have had in the past were trouble free and worked great when new. I have also had 2 diff six pack set ups-one worked/ran great, the other one ran so so. Do the 440 six pack carbs flow more air/fuel than the 340 carbs.
Put a big block 4 speed Scat Pack Dodge in your garage.
Re: Dual feed 850 Holley vs Six Pack on a 440 [Re: rtplumcrazy1] #1072969
09/11/11 04:23 AM
09/11/11 04:23 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I believe the 6 pac will get better mileage when normally driven..
the 6 pac carbs are the same only jetted richer for the 440.
my 340-6 has gotten me better mileage than my 750s that I have ran on it..
I am truckless..
Re: Dual feed 850 Holley vs Six Pack on a 440 [Re: rtplumcrazy1] #1072970
09/11/11 07:00 AM
09/11/11 07:00 AM
Nelson-New Zealand
BIG-MIKE-500 ci Offline
Nelson-New Zealand
One thing most don't realise is 2-barrells & 4-barrells are flowed on a different formula. The six-pac is the equal in flow to 960 cfm 4-barrell.
The main drawback with the six-pac is the manifold. It is quite restrictive so unless you get something like a Hughes Engines Ported one, I'd go with the 4-barrell.
Re: Dual feed 850 Holley vs Six Pack on a 440 [Re: BIG-MIKE-500 ci] #1072971
09/11/11 10:31 AM
09/11/11 10:31 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I dunno my STOCK 6-pack intake and carbs pull really well (shift at 6400-6500) My current best is 11.39 at over 118, car drives great and I ang'd about 11-12 mpg to and from the track. Mostly back roads 45-50mph nice and steady. I like it, keeps pulling and pulling. Nothing wrong w/ a DP thou. I don't think you will lose anything either way. Unless you have amonster motor in which case you'd probably want a BIG carb and single 4.
Coming soon!!!!
Re: Dual feed 850 Holley vs Six Pack on a 440 [Re: rtplumcrazy1] #1072972
09/11/11 01:35 PM
09/11/11 01:35 PM
AndyF Offline
AndyF  Offline
There isn't really an answer for that other than the standard "it depends".
The six pack setup is a great design that works well in certain applications. But once you get outside of its design capability then it doesn't work so great. Same thing with the 850 DP.
Re: Dual feed 850 Holley vs Six Pack on a 440 [Re: AndyF] #1072973
09/11/11 02:08 PM
09/11/11 02:08 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree both work good within their limitations. From what I have seen the 6pk works as good as an 850 DP in any street/strip application. From what I have read in Andy's very good book I feel the 6pk might make more power then the old crossram setup does. Ron
