Broken Transmission Mount #107047
08/18/08 08:33 PM
08/18/08 08:33 PM
Anonymous OP
Anonymous OP
How does a car feel like that has a broken transmission mount on a 727. Does it viberate at a certain RPM and does it viberate when you bring it off idol in park. What does it do?
Thanks Moparts
Re: Broken Transmission Mount #107048
08/18/08 09:12 PM
08/18/08 09:12 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Possible but you should feel it on trans engagement worse in reverse I believe and at shift points. Easy to check, get the car up and place a floor jack on the pan with a piece of 2x12 and put some pressure on the jack, if the mounts bad you'll set it begin to seperate, if it a spool type you'll see the center move way too much, a spool type will also appear to be setting low or against metal when relaxed.
Careful, your character's showing!
Re: Broken Transmission Mount #107049
08/19/08 12:18 PM
08/19/08 12:18 PM
GMP440 Offline
GMP440  Offline
I had one rot away. Felt a scraping under the floor pan when taking off fast on a left hander but no noise when doing right handed turns.
However, when cruising normally I had no vibration issues.
Re: Broken Transmission Mount [Re: GMP440] #107050
08/19/08 12:50 PM
08/19/08 12:50 PM
Anonymous OP
Anonymous OP
for vibration problems under the floor, look at U JOINTS. its Always there
