Summit Fuel Sending Units #1069793
09/05/11 04:40 PM
09/05/11 04:40 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
This one is a MONTH old. The float is STUCK at mid tube. Tapping it on the ground won't free it up. Summit replaced it N/C, but I can't get these things to work long at all.
http://www.summitracing.com/parts/SUM-290181/
Re: Summit Fuel Sending Units [Re: Moe] #1069794
09/06/11 09:09 AM
09/06/11 09:09 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
"Sending unit is compatible with many GM fuel level gauges, verify gauge resistance range. Measures 11 in. long.."
wonder if that has anything to do with it?
Coming soon!!!!
Re: Summit Fuel Sending Units [Re: Moe] #1069795
09/06/11 12:47 PM
09/06/11 12:47 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I have the same type sender that I added to my aluminum fab'd tank in the Torana...it does not work well at all either really...does not seem to be enough spots it reads levels from, and just can't get it to be accurate.
I am going to be be changing it out for a normal style swinging arm type one.
Oh, and they do the Summit ones in different resistances...
