#6/#5 spun rod bearing ?
#1069256
09/04/11 08:19 PM
09/04/11 08:19 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Maybe this is old news and I didn't get the memo, but why is it that these rod bearings,especially #6, are the first to spin on a big block? Also, is there a remedy to fix this issue? Thanks for any good input.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: #6/#5 spun rod bearing ?
[Re: dodgeboy11]
#1069259
09/04/11 10:36 PM
09/04/11 10:36 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Thats the rods I smoked, when the engine run low of oil, before I knowned to put oil restrictors in the oil lines up top. HV oil Pump + Stock Oil pan + Indy heads turning 6800 rpms + spin bearings!
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: 68LAR]
#1069264
09/05/11 10:41 AM
09/05/11 10:41 AM
Posts: 9,835 MI, usa
dvw
MI, usa
Bearings don't spin for without reason. Somewhere, somehow the bearing came in contact with the crank. Trouble shooting the cause takes some detective work. Lack of oil,detonation, aerated oil,wrong clearances, hydrauliced cylinder ,big end distortion of the rod,poor pan design. Plenty of 440 motors around running over 7000 RPM that haven't spun bearings. I would look very carefully during dis-assembly. A very knowledgeable engine builder made this statement. If your engine has to much bearing clearance you will know it. If it doesn't have enough ,everyone will know. Good luck on your diagnosis. Doug
[Re: justinp61]
#1069266
09/05/11 11:11 AM
09/05/11 11:11 AM
68LAR
South Park, Pa.
One bottle of STP treats 5 qts. of oil. My system, 7 Qt. pan, windage tray =1 more qt. and an HP oil filter = 1 more qt. That's 9 qts, and I just add another bottle for GP's. You can't have too much zinc. I run a solid lifter cam, with 1.6 roller rockers. I agree that something had to cause the bearing to spin, my question was, why does it usually happen to #6 or #5 rod, mostly #6? And what can be done to prevent it in the future?
[Re: dvw]
#1069267
09/05/11 11:14 AM
09/05/11 11:14 AM
Posts: 16,925 NC
440Jim
NC
Common causes are loss of oil (various reasons) and detonation beating the bearing up.
[Re: 68LAR]
#1069268
09/05/11 11:18 AM
09/05/11 11:18 AM
Posts: 16,925 NC
440Jim
NC
I am not saying STP is bad, but remember that the oil in the STP bottle that carries the additives may not be the best oil. IMO, the ZDDP additives on the market now in smaller containers (4oz) are a better alternative.
http://www.zddplus.com/
[Re: 440Jim]
#1069269
09/05/11 11:27 AM
09/05/11 11:27 AM
68LAR
South Park, Pa.
I've been using STP for 40 years. I'll probably keep using it. Here's the thing. When I pulled my engine appart, the other 6 rod bearings looked like I just put them in. Same with the mains. There wasn't any bearing left in #6 rod, and #5 looked pretty bad. This engine was assembled by me in 2004......... Again, my question is, why mostly #6 or #5 rod bearing?
[Re: 440Jim]
#1069270
09/05/11 11:28 AM
09/05/11 11:28 AM
Posts: 6,780 Alabama
Mopar-Al
Alabama
Your HP computed from your vehicle ET is 483.36 rear wheel HP and 537.06 flywheel HP. Your HP computed from your vehicle MPH is 500.81 rear wheel HP and 556.46 flywheel HP.
Running a 4 speed and launching at that weight to run those times takes a beating. You really need to do some deep checking to see if you have a main cap issue, thrust bearing clearence incorrect or bent crankshaft. Other issues can also cause your dilema.
Just noticed you say engine has been together for 7 yrs. Did you do any anual inspections? If it went 7yrs of racing on the same build without checking the bottom end, then you actually did very excellent. Parts do go bad after abuse
[Re: Mopar-Al]
#1069271
09/05/11 11:47 AM
09/05/11 11:47 AM
68LAR
South Park, Pa.
I can't truthfully say that I would pull the bottom end appart for inspection each year, because I didn't. I would pull the clutch and transmission down for inspection. I guess that from now on, pulling the engine's bottom end down will be a yearly thing also.
[Re: 68LAR]
#1069272
09/05/11 11:54 AM
09/05/11 11:54 AM
Posts: 52,972 Romeo MI
MR_P_BODY
How many miles on it then how many passes
[Re: MR_P_BODY]
#1069273
09/05/11 12:01 PM
09/05/11 12:01 PM
68LAR
South Park, Pa.
Just a guess, based on approximately 1500 miles a year with usually 4 trips to the track thrown in, something less than 11,000 miles, with more than 140 passes. All just guesses, nothing documented.
[Re: Mopar-Al]
#1069274
09/05/11 12:04 PM
09/05/11 12:04 PM
Posts: 9,997 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Too little flow left over at # 4 to feed the rods enough. Doesn't matter what the gauge says, if it is leaving the main bearing so fast there isn't enough to feed the rods, they starve. I would restrict the passage to the rocker shafts, or feed them externally to keep max oil to #4 main. Also while the motor is down, check clearances on the lifter bores and lifters themselves and any other place oil can bleed off (cam bearings?)due to wear.
[Re: gregsdart]
#1069276
09/05/11 12:17 PM
09/05/11 12:17 PM
MR_P_BODY
My opinion exactly... its too bad we cant get a oil pressure reading at the end of the line instead of near the beginning
[Re: moderncylinder]
#1069283
09/05/11 01:48 PM
09/05/11 01:48 PM
68LAR
South Park, Pa.
#5 main feeds #8 rod #4 main feeds #7 and #6 #3 main feeds #5 and #4 #2 main feeds #3 and #2 #1 main feeds #1
it would appear to me that you have a volume issue if you hurt #5 and #6 since they are fed off two different mains,,, what did #7 look like?
what kind of filter did you have on it,, ive seen restrictive filters hurt rods in th eback of the motor
the "typical" rod that gets hurt in a bb mopar is #3 usually
#7 looked like I had just installed it, like I previously stated. #6 wasn't there. #5 was there but burnt. ALL other rods and ALL mains looked like new. I usually use either a Fram HP1 of K&N hp filter. This time it had a Fram on it. I run a deep sump oil pan and a HV pump. Cold start up it sets on 98 psi. All warmed up and at idle it sets on 65 psi.
[Re: 68LAR]
#1069284
09/05/11 02:41 PM
09/05/11 02:41 PM
Posts: 258 Stockholm, Sweden
TomsCharger70
Stockholm, Sweden
This thread came at a perfect time Lost the oil pressure in my Hemi and it started to knock.. This is what I found when I opened it up. (Sorry for bad picture quality) Its the # 6 Rod bearing (I think) that is sticking out... Havent removed the rods/pistons/crank yet. Is the Hemi block oiling system the same, refeering to.. #5 main feeds #8 rod #4 main feeds #7 and #6 #3 main feeds #5 and #4 #2 main feeds #3 and #2 #1 main feeds #1 and would the Hemi oil system also be better off with restricting the passage to the rocker shafts. Oil system is a external Milodon Dual Line system with a Melling HV pump. No windage tray. I guess in my case I think the spun bearing happened because of low oil volume in the pan.. Ive also been messing about trying to get the E85 carb to run right. Had to change the oil a couple of times because of carb running excessively rich in the beginning. Typical luck for me, the loss of oil pressure happened about the same time I managed to find a nice carb tune.. Though I think the bearing had been messed up longer than that, but it let go right then... /Tom
[Re: TomsCharger70]
#1069285
09/05/11 03:01 PM
09/05/11 03:01 PM
68LAR
South Park, Pa.
Sorry to hear about your damage. Maybe WE all can get some good info from this post.
[Re: 68LAR]
#1069286
09/05/11 03:08 PM
09/05/11 03:08 PM
68LAR
South Park, Pa.
Here's a question for you. What about a rev limiter or 2 step? Could these have an impact on #6 rod bearing going prematurely? MY 2 step was raised toward the end of last year from 4800 to 5400-5600 for my launch. After re-reading some of the replies, how about restricking the oil to the rockers by 1/2. If the existing hole is 1/4", drill and install a 1/8" restrictor. What are the thoughts about this working on a street/strip engine?????
[Re: 68LAR]
#1069287
09/06/11 12:00 AM
09/06/11 12:00 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
There are many reasons bearings spin as stated. There is a good remedy for more equalized Rod bearing oiling posted in the Moparts Power Adder section. I Bumped it to the top for you. Its Feets post on "Any Crank Failures On Boost" Its a good read.
And No, Its not a Fail safe remedy for spun rod bearings. Its just another step in the right direction, IMO
[Re: 68LAR]
#1069290
09/06/11 11:46 AM
09/06/11 11:46 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
That`s EXACTKY what I was thinking plus, 9 quarts of oil AND the stp........I wonder whats going on inside the pan.
What's this mean? I don't get it!
You may have gotten a little carried away with your use of an additive, I can see one bottle, but 3???
[Re: 68LAR]
#1069291
09/06/11 11:49 AM
09/06/11 11:49 AM
JohnRR
U.S.S.A.
Are you oiling the rockers full time? If not don't restrict the oil to rockers The reason being that the stock oiling through the cam only allows oil to the rockers around 15 camshaft degrees....
Ya, my blocks are all stock oiling systems. So I have to live with what I got, and do the yearly tare down and inspection from now on. Thanks to all for good info, Larry
Have you made any of the oiling system changes like that listed in the tech archives?
[Re: Sport440]
#1069294
09/06/11 01:20 PM
09/06/11 01:20 PM
68LAR
South Park, Pa.
Thanks for the bump Mike, good info. I'd like to try that mod, but have 2 questions. How would street driving be affected, and how would I block the oil feed from the cam bearing to the head after the new cam bearing had been installed? Would plugging the holes in the cam work?
[Re: RemCharger]
#1069295
09/06/11 01:21 PM
09/06/11 01:21 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
I agree with the excessive stp deal. 3 in a burned out /6 maybe... The only additive you may need is zinc, and there are better versions of it out there now.
I put my engine into an "extreme over-rev" condition in the spring and it bent # 5+6 exh valves.
What is it about STP? Is it the thickness that is to much and causing the bearings to spin? I used it in an engine for a while that had bearing wear and low oil pressure and it bought me another year.
But I would think too high a viscosity could be a problem, no?
[Re: Thumperdart]
#1069298
09/06/11 03:51 PM
09/06/11 03:51 PM
TomsCharger70
Stockholm, Sweden
Ive been thinking about the spun rod bearing. One thing that crossed my mind is that maybe the reason is that I used to thick oil, 15W20 and ran to much oil pressure in the engine. Cold the oil pressure was 100psi and once engine got warm it was about 60psi. Weirdly the oil pressure did not go up by much at high RPM, about 75psi @ ~7000rpm. The clearances were/are quite loose in the engine, its an old Pro Stock engine. The bearing clearances for main and rod bearings were, if my memory serves me right, in the .0025 something (I cant find my rebuild memo). I left the clearances where they where when I put new bearings in it, clearances were/are a tad loose, but its an old race engine, and my plan was when I bought the engine, that Ill do a service and drive it as is for a season or two, then do a complete rebuild of the bottom end. ..Any ways... The thing that came to my mind is that was the oil to thick and the pressure to high when cold, could that have caused the bearing to spin??? So what do you think, did I up??? /Tom
[Re: Thumperdart]
#1069299
09/06/11 03:53 PM
09/06/11 03:53 PM
68LAR
South Park, Pa.
Yes that and the excessively THICK 98 cold psi and 65 at idle doesn`t seem ideal to me personally. With fairly large bearing clearances in my motor I still run 5w30-10w30 oil and even though I have an 8-quart pan, I run bet 6-7 quarts and have about 70psi cold and 30-40 at idle/cruise.
Cool, you're entitled to your opinion, but tell me this, how many cases of rod bearing failure have you heard of, that was attributed to too high of oil pressure? I'm guessing that I'm allot older than you and I've NEVER heard of high oil pressure causing bearing failure. Granted it robs horsepower, but this is my choice to have higher pressure......... I've heard of many, many more failures due to too low of oil pressure, rather than too high.
[Re: 68LAR]
#1069300
09/06/11 04:05 PM
09/06/11 04:05 PM
TomsCharger70
Stockholm, Sweden
I kinda think there is a possibility that high pressure and loose oil viscosity may cause a bearing to spin, it comes down to physics. IF the clearances are to loose, the thick oil circulating at high pressure, may cause such a "drag", no idea what to call it in English, but the forces at play get so high, that it rotates the bearing?
/Tom
[Re: TomsCharger70]
#1069301
09/06/11 04:13 PM
09/06/11 04:13 PM
68LAR
South Park, Pa.
Bearings are "indexed" so they won't rotate. One reason of what causes a spun bearing is metal to metal contact, or, lose of oil pressure. Your theory may be valid, I'm no physisist, but I'd have to see documented proof. My bearing clearances are .0025", which is in line for my type of engine usage. Nothing exotic, here.
[Re: 68LAR]
#1069302
09/06/11 04:15 PM
09/06/11 04:15 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
I have heard of it "washing" the bearings, That was in an 8500rpm dirt latemodel engine. It would accually just force the oil out of the bearing, I dont understand it for sure either, but the engine im talking about ran 20w50 with .003 rods, and mains, and he had 95+ psi oilpressure, and had a bearing failure on his small block, when he changed the pump to no more than 65psi at the same rpm the bearing issue went away.
so from that I honestly dont know why...
Kasey
[Re: 68LAR]
#1069304
09/06/11 04:44 PM
09/06/11 04:44 PM
Posts: 2,091 Delray beach, Florida
Performance Only
the reality is that the engine needs to come apart completely now anyway, so it's a good time to do the oiling mods and get it over with. there's no reason a street/strip combo should have that much oil pressure. pressure is a result of restriction, keep that in mind. when the engine was built, was each rod checked for size and roundness? oil clearance doesn't mean much if the bearing lacks themproper crush to hold it in place. those index tabs you speak of are just that, a way to locate the bearing. they're in not intended to keep one from spinning in the housing bore. as far as restricting oil to the top end, hogwash. it's a driver, not an all out race car. do the oiling mods in order to get the volume of oil to the places it needs to be. use due diligence in checking housing bore sizes and other standard engine building practices and move on. engine failures are costly, doing it any way but the right way the 2nd time around is even more costly. best of luck.
machine shop owner and engine builder
[Re: maximum entropy]
#1069306
09/06/11 05:08 PM
09/06/11 05:08 PM
TomsCharger70
Stockholm, Sweden
DUDE, you have two different kinds of rod nuts. or am i hallucinating?
Nope, you are correct. A rod nut is a rod nut... Loos weird, but does its job.. story is that previous owner of the engine did a service to it, changed out bearings. He lost two of the nuts, but being a race shop owner he just went into his shop and looked what he could find on his shelves...
/Tom
[Re: Performance Only]
#1069307
09/06/11 05:51 PM
09/06/11 05:51 PM
68LAR
South Park, Pa.
My clearances were checked prior to the build in 2004, as stated, rods and mains WERE all at .0025". The increase in oil pressure is done by me adjusting the pressure relief spring in the oil pump, up a tad. With the relief spring untouched, my pressure was at 65 psi cold and 45 hot. I wasn't comfortable with that. Again, a question of what oil mods I should make, IF any, still has to be anwered. Remember, this is NOT a dedicated race engine. Most of the time it is street driven. DO I NEED TO MODIFY THE OILING SYSTEM????? Right now, to tell you the truth, I'm confused and getting mixed opinions as to IF I do need any mods at all.
Thanks for any input,
[Re: 68LAR]
#1069309
09/06/11 07:16 PM
09/06/11 07:16 PM
Performance Only
i'm just trying to help. did you ever check the housing bores for size and roundness? frankly, most home builders don't because they don't have the proper tools or experience to do it. 65 psi cold is a smidgen low on a cold motor, but not what i would be concerned about. what was the pressure hot at 6000 rpm? that's way more important in my book. i'm just saying, IMO you should do the oiling mods. it's not voodoo, it helps. the basic mods are fine although i still prefer the 1/2" oil pickup. are you running a std or high volume oil pump?
[Re: 68LAR]
#1069310
09/06/11 07:16 PM
09/06/11 07:16 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
I'd suggest get chuck senatore's old book, and ream + clean up the passages between the oil galley and the mains the way it's spelled out in there. Other books say it in one sentence, but that one explains exactly what to do. If you've never checked out what a mess those particular oil passages are in a stock block you're in for a real treat. It would not surprise me if you found a couple holes that are 2/3 the size of the others, and that would do it. For the type of use, I would not restrict the oil to the rocker shafts with an stock (other than above) system. Considering the preference for high viscosity oil/additive, that stp adds a whole bunch of viscosity....but if you like it, go ahead and use it....I also think it's a good candiate for the old direct connection "hemi" 1/2" oil pickup, radius and blend the pickup passage modification. SAE 50 and 40 weight were commonly used back when the books detailing those mods came out. All that will give you more flow (volume, not pressure) through the system......it should definitely help
Rich H.
Esse Quam Videri
[Re: 68LAR]
#1069311
09/06/11 07:36 PM
09/06/11 07:36 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Settle down skippy...............wasn`t refering to the spun bearing just damn thick oil that`s all and another thing, older DOESN`T make you smarter. Now where were we?
#1069312
09/06/11 07:40 PM
09/06/11 07:40 PM
68LAR
South Park, Pa.
I know you are trying to help. It's hard to show feelings with a key board. I appreciate all of the replies so far, really! I did not check bore size because of the reason you mentioned. 65 psi was cold idle. At 2200 rpm it was at 75 rpm. I didn't take it up higher than 3500 and it remained at 75. When I raced it with the engine at temp. my oil pressure sets, or sat at, 75-80 psi at 6500 rpm. With that, what mod would you recommend? I'm leaning toward the one that blocks the oil from #4 to the cam bearing and drill and tap in a restrictor into the main oil galleies for rocker lubrication. If any mods, to me, this one as described in the "Power Adder" section, would work best on a street/strip engine like mine.
I guess that I forgot to mention. I already have a 1/2" pick up with a high volume pump.
[Re: 68LAR]
#1069317
09/06/11 08:08 PM
09/06/11 08:08 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Larry, I'm not trying to be a smart azz, but if you're supposed to use five quarts of oil to one bottle of STP, why use three bottles to nine quarts? I think in it's day STP was great stuff, but now there are better products out there. Yes, I ran STP for years, but only one bottle. I'd be curious to see what your oil viscosity is with you're mix. The oil may not have anything to do with your problem, but I've have never heard of anyone using that much STP. My 408 has the oil passages drilled out, full grove mains, .0025 on the rods and .003 om the mains and a high volume pump. It runs about 60 psi hot at 2800 and around 40 at idle. I know the volume is there so the pressure doesn't bother me. I hope you find and correct your problem and have no issues in the future .
[Re: 68LAR]
#1069318
09/06/11 08:50 PM
09/06/11 08:50 PM
Performance Only
i wouldn't block any oil to the top end. the pressures you listed above are fine. we run similar pressures on engines that regularly see 7000+ rpm at the track and get driven hard on the street. it's all about volume, not pressure. open up those main passages so the volume gets to the bearings. you'll be surprised how small some of them are as cast. having the 1/2" pickup is great, but by itself it doesn't help much. you need the other passages opened up for it to be effective. one other thing, replace the rod that spun the bearing, don't repair it. if the one next to it got hot, make sure it's checked out preperly or replace it too. hopefully the rest of the damage isn't too bad.
[Re: 68LAR]
#1069319
09/06/11 09:03 PM
09/06/11 09:03 PM
MR_P_BODY
Also you want the volume... its also removing heat... like was said already, pressure is the by-product of flow vs restriction... you would have plenty of flow with what you have BUT with the thick oil and the restrictions you have lots of pressure
#1069320
09/06/11 09:03 PM
09/06/11 09:03 PM
68LAR
South Park, Pa.
Will do! I did ordered 2 new rods and a new piston for #6, as it hit the head. I also had to order another crank, mine showed a couple of cracks. I get carried away with things from time to time. The STP thing is one of those times. Maybe it contributed to the failure, maybe not, remember this engine was built in 2004..... Thanks to ALL for your input, believe me, it is appreciated. Thanks again. Larry
#1069321
09/07/11 12:47 AM
09/07/11 12:47 AM
Sport440
Canton, Ohio
There are different reasons for restricting oil to the top end. The cam itself is a "Pulse oil restrictor" to the top end.
In a race engine, a additional restrictor will also help to prevent to much oil from pumping to the top end at high RPM draining a insufficient pan.
Some will groove the cam journal for a constant oil supply to the top end vs a Pulse cam supply. That would need a restrictor to the top end.
The Mod in the Power Adders section has a restriction too. As does All the above situations.
But, The Power Adders Mod addresses the #4 main Oil supply drain of the valvetrain that Robs the oil supply to #6 and #7 rod journals that get the First hit of a weak oil supply.
All the other mods wont! They will still pull/rob oil from the #6 and #7 rod bearings to feed the upper valvetrain.
At minimum while your block is apart drill the angled oil galley feeds from the mains to the oil galley to make sure they are clear "all the way through".
The "Power Adders Mod" is alittle extreme for your ride IMO. But, I would still consider a Jet restriction in the block or head for your ride. Lighten up on the STP too a little.
Your car is Mostly a street car. But with the 11.sec. trips down the 1/4 it still thinks its a race car. If and when any bearings run out of oil @ 6000 RPM, Does it care??
#1069324
09/07/11 09:37 AM
09/07/11 09:37 AM
gregsdart
After rereading my post and the rest of them, PERFORMANCEONLY is spot on IMHO. Also consider this. Too much viscosity can starve a bearing. I would never use an additive that increases viscosity because the oil engineers know what they are doing, and why. There is a constant loss of pressure as a liquid moves through a tube. Thicken the liquid, and the rate of pressure loss due to friction sky rockets. Sometimes a thinner oil is much better in certain circumstances than thinner oil. Given that a lighter oil will still support the load, you have more capacity (flows easier) and more cooling. But your motor should work just fine with 15w40 if the passages are ok and bearings etc are done right. The restriction I talked about also hurts you on the suction side. Then when the oil is trying to move through the motor there is more loss. Stack everything together and the answer to why the bearings failed is in there somewhere. An extreme example of what I am talking about with pressure loss happened at the newspaper where I used to work. The ink we pump hundreds of feet to the press is thicker than 600w grease. The engineering study said to run huge (8 inch?) pipe to overcome the friction. Some genius said it cost too much, and reduced the size of the pipe in the plans. Guess what? The presses on the end of the line couldn't get enough ink when the first ones were running. As far as pressure needed, I run 65 psi at idle cold. Never goes above 65 psi. .0025 rod/.0035 main clearances, 7200 to 7800 rpm at the stripe. No problems. I do run the motor hot, which keeps the viscosity down some.
[Re: 440Jim]
#1069326
09/09/11 02:13 PM
09/09/11 02:13 PM
Posts: 179 Up in the North and Far Away
AutoEngineer
As a matter of fact, you CAN also have too much zinc in the motor oil. Too much zinc increases the formation of sludge and pitting of metal surfaces.
STP is also containing additive called Viscosity Modifier and they are polymers. By using an additional STP bottle, you are also pouring more plastics to the crankcase. Certain aftermarket oil additives are also containing chlorinated paraffin that one type of an active chemical ingredient. It is causing bearing weight loss. The lubricant industry is using a bench test ASTM D5119 to evaluate an oil's ability to control copper/lead/tin corrosion of bearings. Using aftermarket additives you most often improve the chemical corrosion of the bearings. Read the attached pdf file copied from a lubricants professional journal a few years ago
The US Federal Trade Commission has had a few cases against aftermarket motor oil additive sellers
STP Engine Treatment http://www.ftc.gov/opa/1995/12/stp.shtm
Valvoline Engine Treatment http://www.ftc.gov/opa/1997/10/valve.shtm
Slick 50 Engine Treatment http://www.ftc.gov/opa/1996/07/slick.shtm
Dura Lube Super Engine Treatment http://www.ftc.gov/opa/1999/05/duralub2.shtm
Motor Up Engine Treatment http://www.ftc.gov/opa/1999/04/motorup5.shtm
Prolong Super Lubricants http://www.ftc.gov/opa/1999/09/prolong.shtm
Make your own conclusions from the above, but as a lubricants professional and formulator of lubes I would prefer to use high quality lubes instead of making own mixtures with aftermarket additives. You can't necessarily improve an oil by pouring in more additives from an expensive little bottle. As a matter of fact, you even can make things worse. Overdosing STP may not have been the one and only reason for the spun rod bearings, but sure it has had it's own negative reactions to the motor oil
[Re: AutoEngineer]
#1069327
09/09/11 06:56 PM
09/09/11 06:56 PM
68LAR
South Park, Pa.
Not trying to start an argument here, but 2 things come to mind. 1. Why did the other bearings, rods and mains, look like new? 2. There ain't no sludge in my engine, or pitting, for that matter.
Thanks for your input though!
[Re: 68LAR]
#1069328
09/10/11 03:26 PM
09/10/11 03:26 PM
AutoEngineer
I am not going either to start arguing here clear issues, but someone stated here that you can't have too much zinc in motor oil. That is NOT the truth and it has been a very long time well known issue among people who are working with the R&D of lubricants.
Like said, your bearing failure may not have been a direct result of overdosing STP, but statements here won't renew the basics of science like chemistry and tribology. Too much zinc in the oil causes problems. Period
This is the end of this discussion from my side.
