Dome light wiring #1069168
09/04/11 06:45 PM
09/04/11 06:45 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
Does anyone have a '70-'71 Duster with the head liner out. I'd like to know where the wires from the dome light go down to the body wire harness (front "A" pillar or back towards the trunk?). Should be two 18 blacks coming off the dome light plugged into a 18 yellow and purple. Then plugged into a 18 yellow and purple going to Instrument wiring panel.
Thanks. duster@surewest.net
Re: Dome light wiring [Re: bigblock340power] #1069169
09/04/11 07:28 PM
09/04/11 07:28 PM
okla.
O
okie Offline
okie  Offline
O
okla.
It has been a while but I think they go down the drivers side in the front, should have the plugs right behind the kick panel. Good Luck Ronnie
Re: Dome light wiring [Re: okie] #1069170
09/04/11 08:22 PM
09/04/11 08:22 PM
Elk Grove, Calif.
Elk Grove, Calif.
Thank you for your reply.
I found the wires I was looking for going down the back sail panel area. I took the metal sail panel off inside the car around the back kick out window. There sitting right behind a little body panel hole were the wires with the male pig tail I needed. Plugged it in, and voile! The dome light, she works.
Thank the car gods. They were good to me today. I only lost ten pounds sweating. Thank you. Thank you. Thank you.
Re: Dome light wiring [Re: bigblock340power] #1069171
09/04/11 09:12 PM
09/04/11 09:12 PM
okla.
O
okie Offline
okie  Offline
O
okla.
I guess they are different than a Dart. Ronnie
