Vinyl top molding clip - Recognize this one? #1068396
09/03/11 10:37 AM
09/03/11 10:37 AM
South-Central (Sebring), FL
Commando1 Offline OP
My New Yorker was sold with a dealer (aftermarket)installed vinyl top.
I need new clips so I can pop off the trim so as to paint the car. The very first one I tried broke so I'm not expecting good luck with the rest.
I have searched every automotive fastener supply company/catalog that Google can produce. Not one has even come close. Any help? Thanks.
Re: Vinyl top molding clip - Recognize this one? [Re: Commando1] #1068397
09/04/11 01:36 AM
09/04/11 01:36 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
If you can get ahold of an AuVeCo catalog I bet you could find something which would work.
In lieu of that, that trim piece looks to be about the same width as the beltline trim used on '71-'77 B-vans, so if you can post some measurements or the trim (where the clip rests) I can check to see if I have anything which might work.
Re: Vinyl top molding clip - Recognize this one? [Re: In_The_Pink] #1068398
09/04/11 09:29 AM
09/04/11 09:29 AM
The Au Ve Co catalog was the first place I went to.
Unless I missed something.
Basically, the back side of the trim is hollow and "snaps" onto the clip. There are no slots to allow sliding in the more common type of retainers.
Re: Vinyl top molding clip - Recognize this one? [Re: Commando1] #1068399
09/05/11 12:11 AM
09/05/11 12:11 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Check out these two places:
http://automotive-hardware.com/auto-body-clips-c-14.html
I sent a similar style nylon clip to this place and they matched it for me:
http://northlandfasteners.biz/Store/index.php?cPath=288
Re: Vinyl top molding clip - Recognize this one? [Re: 68CoronetRT] #1068400
09/05/11 01:40 AM
09/05/11 01:40 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
With a bit of time, patience, a drill & a table saw, that looks like it could be duplicated fairly easily with some PVC stock.
Re: Vinyl top molding clip - Recognize this one? [Re: Alaskan_TA] #1068401
09/05/11 12:16 PM
09/05/11 12:16 PM
I dunno....
