Re: Cleaning out water passages in my 383
[Re: Challenger 1]
#1066043
08/31/11 07:47 PM
08/31/11 07:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
YOU sure the block cracked and didn't rust thru the cylinder? had that happen on the flathead in the 38 Plymouth I bought. If it weren't for that I think I could of gotten it running.
[Re: Supercuda]
#1066044
08/31/11 09:02 PM
08/31/11 09:02 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
OP has a much harder time since his engine is assembled.
I did my bare block 360 on the engine stand with all core plugs removed, outside on a hot day with a garden hose and coat hangers, etc and compressed air. VERY messy job, got orange crap flying everywhere. But I was actually pretty pleased, all the sludge and major scale came out of the block, casting was 90% clean when I was done, then I needed about an 1/2 hour shower myself...
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Supercuda]
#1066045
08/31/11 09:11 PM
08/31/11 09:11 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
You guys running acid in the block, make sure you run a dose of baking soda though it or something with a lower PH to neutralize the high PH acid. I think baking soda and water is a neutralizer. If not, it can sit in there and keep eating if you dont put it back into service ASAP. Check on slantsix.org for Dutra wisdom...
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
