soldering wires, what 2 use
#1064093
08/28/11 12:22 AM
08/28/11 12:22 AM
RapidRobert
Some heavy wires, soldering gun & even the big iron was too light & tried propane but the flame is too wide & wants 2 melt the insulation at either end of the joint. Any suggestions? Thank you 4 your time
Re: soldering wires, what 2 use
[Re: RapidRobert]
#1064095
08/28/11 12:31 AM
08/28/11 12:31 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
For 4-8 ga wire I typically use a crack pipe lighter...
[Re: 1_WILD_RT]
#1064098
08/28/11 12:50 AM
08/28/11 12:50 AM
RapidRobert
I'm assuming the flame can b turned down low. Alright I'll go get one (but not from my crack head neighbors)
[Re: T2R9]
#1064100
08/28/11 10:02 AM
08/28/11 10:02 AM
RapidRobert
Yeah that looks worthwhile (refillable/diff tips)
[Re: RapidRobert]
#1064101
08/28/11 01:01 PM
08/28/11 01:01 PM
Posts: 15,491 the boonies
aarcuda
the boonies
i have thia cool little setup that is a mini torch that that a rechargeable butane lighter in it. bought it years ago and works like a charm
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: RapidRobert]
#1064102
08/28/11 01:06 PM
08/28/11 01:06 PM
Challenger 1
Cincinnati, Ohio
I soldered some 10 ga wire last night onto a couple alligator clips for a 12volt contractor fuel pump in the bed of my pickup truck. I used a gun type soldering gun and was able to easily have enough heat to get the allligator clips hot enough to flow the solder out. These clips go on 12V batterys, they are not small. If the wire is corroaded or dirty it won't take solder. I work on petroluem tanker trucks everyday, those hand held torches are scaring the crap out of me.
[Re: Challenger 1]
#1064103
08/28/11 01:19 PM
08/28/11 01:19 PM
Posts: 3,892 Oregon
hooziewhatsit
you did put a blob of melted solder on the tip of the iron, then put it on the wire(s) to be soldered, right? If the tip is clean, it won't transfer hardly any heat. Otherwise, strip the insulation back an inch or two, then clamp small vice grips on either side of the joint. They'll absorb most of the heat and prevent it from messing up the insulation. Then slide your shrink tubing (that you put on before solding the joint) over the entire joint.
[Re: DrCharles]
#1064108
08/28/11 01:43 PM
08/28/11 01:43 PM
Challenger 1
Cincinnati, Ohio
Make sure you have a good mechanical connection first... tin/lead solder tends to fracture under high vibration (like an automotive application) especially if it's in tension.
If you've got room, perhaps one of these? They come in many sizes...
Oh yea that'll look good on my dragster...light weight too.
Next thing you know we will have scrappers stealing stuff off our cars if we used connections like that.imo
[Re: Challenger 1]
#1064109
08/28/11 01:50 PM
08/28/11 01:50 PM
RapidRobert
You know I'm wondering if I DIDN'T tin both wires enough . (& I'm always preaching k.i.s.s./basics) I'll b back on it today. Charles that clamp oughta do it but I'd (prob) still wanna solder it & if it's as big as it looks I'd be dragging out the acetylene
[Re: RapidRobert]
#1064111
08/28/11 03:20 PM
08/28/11 03:20 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
those lugs come in pretty small sizes (home depot or such)and are you using rosin core solder or solid?
