70 E body 4spd Bellhousing Ball Stud Bracket Question
#1063652
08/27/11 12:19 AM
08/27/11 12:19 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Been a while since I took this apart and my service manual is for a 72. Question is, I know there is a bolt that goes through the lower hole of the bracket but it seems the ball stud is too small to hold the bracket down. Should there be a washer on the ball stud to hold the bracket down at that spot? I don't recall there being one and there was not one in my ball stud bag.
Thanks, Joe
65 Barracuda 70 Challenger
Re: 70 E body 4spd Bellhousing Ball Stud Bracket Question
[Re: jrwoodjoe]
#1063654
09/01/11 10:41 AM
09/01/11 10:41 AM
Posts: 4,285 Ohio
64dodge572
Ohio
Small or Big block? Either way the ballstud screws into the bellhousing, its not part of a bracket. No washer under the ballstud either. Are you asking about the pivot bracket for the column lock linkage? Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
