The tech archive states that the MP electronic ignition dist. is set up to bring the timing all in by 2400 rpm. If I wanted 32 degrees total with an idle speed of 750 rpm (in gear), I would set my initial timing to 10 degrees BTDC, correct? I don't want to have to rev the car and make a bunch of noise to reset the timing. Am I off base here? Here is the formula I used to calculate the initial:
32 degrees total / 2400 rpm = .01333
.01333 X 750 rpm = 10 degrees
EDIT - I realize that this equation will only work if the dist "curve" is straight.
