Re: I'm back with a new Mopar project!
[Re: DusterDave]
#1062073
03/08/15 01:33 PM
03/08/15 01:33 PM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
That really sounds great and looks great. You have an incredible knack for building vehicles.
[Re: rickstershemi]
#1062075
03/08/15 09:32 PM
03/08/15 09:32 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Major Congrats Dave....Bet that felt great Can't wait until you get it all sorted out for some thrilling black mark video....sounds great !!!!!!
That's gonna be awesome for skirt viewing
Rickster
Thanks, Rick and Blusmbl. To be honest, Rick, it wasn't that enjoyable of a ride, because this was the final exam for all of my ideas and hard work, and I was well aware that Murphy's Law could kick in at any moment and ruin my day. However, it was a relief that I passed the test. Future drives will be more enjoyable. It was an absolutely beautiful day here in Tampa, but unfortunately I couldn't take the Jeep out, because I have to replace my pitman arm. The one that's in there now was banging against my tie rod, and I don't want to drive more and do more damage to the tie rod. The new pitman should be here in a day or two. From the first ride alone, I can tell there are two things I want to do. First, change the mufflers to some quieter ones. This isn't a hot rod, and I want to enjoy my nice stereo system. Second, I want to install a front sway bar.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: dusturbd340W5]
#1062077
03/09/15 08:55 PM
03/09/15 08:55 PM
Posts: 1,845 Tampa
DusterDave
Tampa
To address the less than sports car-like handling, I purchased a Currie AntiRock sway bar kit.
To address the excessive exhaust decibels, I purchased a pair of Dynomax Super Turbo mufflers to replace my very nice, but loud, Hooker AeroChamber mufflers. I spent some coin on a stereo system, and I'd like to be able to hear it while I'm driving.
[Re: DusterDave]
#1062082
03/15/15 07:52 PM
03/15/15 07:52 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Several days ago, I swapped out the Hooker AeroChamber mufflers with a pair of Dynomax Super Turbo mufflers. While it did quiet it down some, I discovered some major exhaust leaks where the primary header pipes slip into the collectors. This coming week, I'm going to seal up these leaks with Permatex 80335 Muffler & Tailpipe Sealer. Sealing up these leaks will help to further quiet down the exhaust system.
I took it out for another drive today. I recently had some coolant leak out of the radiator overflow nipple on several occasions. I tried a higher pressure radiator cap, and that seems to have solved the problem.
[Re: DusterDave]
#1062084
03/18/15 12:11 AM
03/18/15 12:11 AM
Posts: 1,845 Tampa
DusterDave
Tampa
A couple short clips. The front end and steering feel a bit squirrelly and unpredictable, so I decided to hold off on really nailing the go pedal at this time. Leaving Approaching
[Re: Blusmbl]
#1062088
03/20/15 07:20 PM
03/20/15 07:20 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
A friend of mine built a nasty AMC 360 motor for a CJ5 he had. He said it was without a doubt the easiest vehicle to scare passengers with.
68 Barracuda Formula S 340
[Re: DusterDave]
#1062091
03/29/15 12:38 AM
03/29/15 12:38 AM
Posts: 1,845 Tampa
DusterDave
Tampa
We drove the Jeep out to Wing House tonight. It was the first time I actually drove it to a destination. During the drive to and from, I noticed several electrical issues. First, my right turn signal indicator comes on, but doesn't blink. Second, my oil pressure gauge wasn't illuminated when I turned on the headlights. Lastly, on the ride home, at about the halfway point, my headlights completely went out. Fortunately, I was only about a mile and a half from home when it happened, and the streets were well lit.
