Re: I'm back with a new Mopar project!
[Re: DusterDave]
#1062055
03/01/15 02:50 AM
03/01/15 02:50 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
It's Saturday.
It's also pouring outside. I really wanted to make the test drive on a dry day, so I could see if I'm trailing any fluids, plus I want to have the hood off, so we can see if and when the cooling fan kicks on automatically, or if anything is smoking in the engine compartment, we can spot it immediately.
Remember People .... It's a Mall Crawler .... Getting it wet or dirty is not in the plan.....J/K
Rickster
I had a feeling someone would go there!
You can always count on me Dave....I will never let you down
Rickster
[Re: Shoozy]
#1062059
03/02/15 12:26 AM
03/02/15 12:26 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Thanks, guys. We bled the power steering and hydroboost this afternoon, but I've been told by several sources that it will take a little time to work out all of the air bubbles from the power steering and hydroboost. I discovered several brake line fittings that needed tightening. I might have to do some more bleeding on the brakes, because the pedal feels soft to me. I'll work on that during the week.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: Triple Threat]
#1062061
03/07/15 04:31 PM
03/07/15 04:31 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I can see the local news headlines now: DAVE TAKES HIS NEW JEEP FOR ITS FIRST TEST DRIVE.....FILM AT ELEVEN."My buddy and I took her for about a 5 minute ride. My initial observations: - nothing broke, fell off, overheated, or leaked - the trans shifts into every gear - for the first time, the thermostatically controlled electric cooling fan kicked on by itself, within 5 degrees of where I set it. - This thing definitely does NOT have sports car-like handling around the turns! - The GPS speedo did not work at all. Will need to diagnose - the pitman TRE beat up the paint on my tie rod. The new pitman arm is "supposed" to arrive today, but USPS is delivering it, so who knows when I'll get it. I need some time to edit the video, so look for it sometime tonight.
[Re: DusterDave]
#1062064
03/07/15 09:56 PM
03/07/15 09:56 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Here's the video of the first test drive. Magnum Force Test Drive
[Re: DusterDave]
#1062065
03/07/15 10:00 PM
03/07/15 10:00 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Awesome. The Jeeps looks great. I know the feeling of finally driving a project for the first time.
What brand GPS Speedo? I have Speedhut and it works great.
Autometer. When I start it up, it says that its "Acquiring Signal." My GPS antenna is buried under my dash, could that be the problem?
yes, the antenna needs line of sight to the satellites. Just like satellite radio. you need to mount it atop the dash by the windshield.
