Re: I'm back with a new Mopar project!
[Re: Quicktree]
#1062016
01/19/15 01:21 PM
01/19/15 01:21 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Its always a good feeling to fire one up for the first time.
68 Barracuda Formula S 340
[Re: DusterDave]
#1062028
02/09/15 12:52 AM
02/09/15 12:52 AM
Posts: 1,845 Tampa
DusterDave
Tampa
After 3-1/2 years of this Jeep-building juggernaut, it is appropriate at this time to borrow a line from that one-hit-wonder rock group, Europe: IT'S THE FINAL COUNTDOWN !!!
Here is what I have left to do on the Jeep, to make it drivable.
1. REAR AXLE: a: Set the pinion angle on the rear axle b: Tack weld spring perches and lower shock mounts c: Get rear axle out, finish weld and paint it d: Install rear axle
2. Make brake lines that go from frame rail to master cylinder
3. Fill & bleed power steering/hydroboost system
4. Bleed brake lines. Instead of the usual two man brake bleeding operation, for this project I decided to purchase a Motive Products Power Bleeder.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1062029
02/09/15 01:31 AM
02/09/15 01:31 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
[Re: DusterDave]
#1062031
02/10/15 12:55 AM
02/10/15 12:55 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
https://www.youtube.com/watch?v=9jK-NcRmVcw
I was actually thinking about adding a link to that video!
Just play it on a continuous loop in the shop and you should be able to get all that stuff done pretty quickly.
