Page 49 of 55 1 2 47 48 49 50 51 54 55
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061993
12/22/14 01:46 AM
12/22/14 01:46 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Measure the transfer case input diameter and see what your seal measures. There are two different seals depending on the transfer case being used.
Re: I'm back with a new Mopar project! [Re: NITROUSN] #1061994
12/22/14 01:17 PM
12/22/14 01:17 PM
Tampa
DusterDave Offline OP
Tampa
I found this pic that I had snapped the day I bought the 727. I don't see any seal inside, just a bearing deep inside the extension housing. Maybe its designed to run wet (no shaft seal on the bearing), which would explain the big black rubber gasket. I forgot it had a gasket there.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061995
12/22/14 09:09 PM
12/22/14 09:09 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I don't believe 80-87 had a seal. The gasket should work unless there is a small weep opening cut into the case. What transfer case are you using?
Re: I'm back with a new Mopar project! [Re: NITROUSN] #1061996
12/22/14 09:16 PM
12/22/14 09:16 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
That "rubber" gasket isn't black silicone is it?
When you decide to quit, THAT is the moment when you would've succeeded..
Re: I'm back with a new Mopar project! [Re: NITROUSN] #1061997
12/22/14 10:39 PM
12/22/14 10:39 PM
Tampa
Tampa
NP231.
Re: I'm back with a new Mopar project! [Re: KatFysh] #1061998
12/22/14 10:41 PM
12/22/14 10:41 PM
Tampa
Tampa
No, it was an actual gasket. Gasket only, no silicone. From the looks of it, I would guess it was the original factory applied gasket.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061999
12/22/14 10:42 PM
12/22/14 10:42 PM
Tampa
Tampa
I purchased the trans to transfer case gasket. If I have time this weekend, I'll drop the t-case and install it.
Meanwhile, I've been forging ahead with the stereo system install. I mounted the amplifiers to the floor, which required fabbing up some mounting brackets. I also made a mounting bracket for the front passenger side speaker. I plan to make the mounting bracket for the driver side front speaker tomorrow.
I built speaker boxes for the rear 6x9's. They will be sprayed with black Monstaliner this week. The front enclosures will also get the Monsta treatment.
The new hydroboost unit showed up yesterday.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062000
12/27/14 07:42 PM
12/27/14 07:42 PM
Tampa
Tampa
The stereo system installation is 100% DONE. I haven't turned it on yet, because I've been going non-stop all day, and I needed a break. I will test it out later on today, but for now, I thought I'd post a few pics of the install, the speakers in particular. The speaker enclosures, and how to mount them, took the most time, effort and creativity. The front passenger side speaker was a real challenge, because of the lack of room. The drivers side had much more room to work with, so I incorporated features in the mount to allow for swiveling and rotating of the speaker enclosure. Both front speakers are tucked in as much as possible, for maximum foot room.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062001
12/28/14 03:11 AM
12/28/14 03:11 AM
Tampa
Tampa
I turned on the stereo system for the first time tonight. Sounds GREAT!! I was running it off of the battery charger, so I didn't try to turn it up super loud, but I'm happy with the sound quality. It will perform even better when it's hooked up to the battery.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062002
01/03/15 11:10 PM
01/03/15 11:10 PM
Tampa
Tampa
OK, with the installation of the gasket between the trans and the t-case out of the way, I can get back on schedule with the installation of the interior and ..........wait for it.................. starting the engine!!! I'm aiming for next weekend for the big start up.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062003
01/04/15 12:27 PM
01/04/15 12:27 PM
ohio
all spooled up Offline
ohio
Re: I'm back with a new Mopar project! [Re: all spooled up] #1062004
01/10/15 05:38 PM
01/10/15 05:38 PM
Tampa
Tampa
Zero hour is fast approaching. I'm in the process of installing the dash, which is the last thing on the list before I can turn the key and (hopefully) hear this stroker smallblock Mopar come back to life again.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062005
01/10/15 09:31 PM
01/10/15 09:31 PM
Tampa
Tampa
Well guys, no excalibur today. My distributor is a piece of junk. Dan had problems with it at the dyno session, and it is giving me problems now. We tested the MSD box and coil, and they are working as they should. I've ordered another, better quality distributor, an MSD Pro Billet distrubutor. should be here in a few days. When it arrives, I'll stab it in, and try again.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062006
01/11/15 12:21 AM
01/11/15 12:21 AM
Lehigh Acres, Florida
rickstershemi Offline
what dizzy do you have...?????
Rickster
Re: I'm back with a new Mopar project! [Re: rickstershemi] #1062007
01/11/15 01:29 AM
01/11/15 01:29 AM
Tampa
Tampa
Rickster
I "think" it was either a cheap Accel or a Jegs distributor. I bought it new from Jegs. The engine wouldn't start on the dyno. Dan tinkered with the internals (don't know what he did), and got it to run.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062008
01/13/15 12:11 AM
01/13/15 12:11 AM
Tampa
Tampa
While waiting for the new distributor to come in, tonight I installed the steering column and steering wheel.
Random pic of the amps and 10" Kicker subwoofer installed. The hinged lid for the center console storage is at the auto upholsterers shop, getting recovered in black and red vinyl.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062009
01/17/15 12:15 AM
01/17/15 12:15 AM
Tampa
Tampa
The MSD distributor is installed. Going to try starting it up tomorrow.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062010
01/18/15 02:36 AM
01/18/15 02:36 AM
Tampa
Tampa
THE ENGINE RUNS!!!
One of the wires for ignition power was on the wrong terminal on the back of the ignition switch. Once this was fixed, the engine started right up.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062011
01/18/15 09:37 PM
01/18/15 09:37 PM
Tampa
Tampa
After 3 and a half years.......IT'S ALIVE!!!! The spirit of Dan Costello lives on!!! That fire-up was for you, Dan! RIP, brother!
ITS ALIVE!!!!!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062012
01/18/15 11:34 PM
01/18/15 11:34 PM
ITS ALIVE!!!!!
Awesome....Congrats Dave Sounds Healthy....Can't wait for the fist test drive vid
Rickster
