Page 36 of 55 1 2 34 35 36 37 38 54 55
Re: MY JEEP BUILD THREAD [Re: 340SHORTY] #1061733
02/09/14 01:06 PM
02/09/14 01:06 PM
Tampa
DusterDave Offline OP
Tampa
Hey 340SHORTY, thanks for the thread bump and increasing my views count! I appreciate it!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061734
02/09/14 04:15 PM
02/09/14 04:15 PM
Lehigh Acres, Florida
rickstershemi Offline
Nice......Perfect for getting those pesky grocery carts out of the way
Really coming along Dave
Rickster
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061735
02/09/14 05:39 PM
02/09/14 05:39 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
No prob.. I love this build. Your work is second to none.
I am truckless..
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061736
02/09/14 07:19 PM
02/09/14 07:19 PM
Tampa
Tampa
Rickster
They have grocery carts at malls???
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061737
02/09/14 08:23 PM
02/09/14 08:23 PM
Tampa
Tampa
It was a beautiful sunny day in the 70's here in Tampa today, perfect weather for painting, so I prepped and epoxy primed the PSC front bumper and my newly created rear tube fender flares.
This is the epoxy primer I used. If you are looking for a heavy bodied, industrial strength epoxy primer with outstanding adhesion properties and isn't too expensive, I highly recommend Dupont Corlar 2.1 ST. Out of the can, this stuff has an extremely high viscosity, and even after reducing it 20%, it still requires a spray gun with at least a 2.0 tip and sprayed at a minimum 50 psi. For this, I use an el cheapo $20.00 Harbor Freight spray gun with a 2.2 tip. With this gun sprayed at 50 psi, the Dupont Corlar 2.1 ST lays down with a nice subtle texture. I'm going to finish these parts with black Monstaliner.
Re: MY JEEP BUILD THREAD [Re: 340SHORTY] #1061738
02/09/14 10:31 PM
02/09/14 10:31 PM
Tampa
Tampa
what size Winch are you going to install to help you get over those curbs in the mall parking lots ??
I think I might get this one.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061739
02/09/14 11:15 PM
02/09/14 11:15 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
that will help get it over those curbs..
I am truckless..
Re: MY JEEP BUILD THREAD [Re: 340SHORTY] #1061740
02/10/14 05:01 PM
02/10/14 05:01 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
And just in case you need a spot, you can always make a new one. Someone's just going to have to find where you put their car.
Re: MY JEEP BUILD THREAD [Re: MuuMuu101] #1061741
02/15/14 01:06 AM
02/15/14 01:06 AM
Tampa
Tampa
DATELINE TAMPA:
A MILESTONE HAS BEEN REACHED AT JEEPER DAVE TRAILSPORTS, A WHOLLY OWNED SUBSIDIARY OF DUSTERDAVE MOTORSPORTS.....
BODY WORK HAS OFFICIALLY BEGUN!!!
I spent a good part of today doing the body work on the front of the grille. As you can see, it needed a lot of attention to get it straight. Since I sanded down to bare metal on some spots, tomorrow I'm going to spray a single coat of epoxy primer, followed by several coats of high build. A final sanding with 320 grit, and this piece will be ready for paint.
New tubular fender flares mounted, waiting for their coat of black Monstaliner.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061742
02/20/14 01:35 AM
02/20/14 01:35 AM
Tampa
Tampa
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061743
02/20/14 12:35 PM
02/20/14 12:35 PM
Cool Dave.....Cutout is an interesting idea and looks sharp
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061744
02/20/14 01:39 PM
02/20/14 01:39 PM
Tampa
Tampa
Thanks, Rick. Some aftermarket Jeep fenders have the same basic cutout, so I basically stole the idea from them. It's done to let excess engine heat escape.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061745
02/23/14 09:52 PM
02/23/14 09:52 PM
Tampa
Tampa
As each part of the body is block sanded straight, they are shot with one final coat of epoxy primer, and two coats of high build yellow primer.
For some reason, Kate Upton wearing a peekaboo negligee comes to mind.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061746
02/25/14 12:31 AM
02/25/14 12:31 AM
USA
Hooligan Offline
Hooligan  Offline
USA
Yeah...I see it too! However, Kate's headers speak louder to me!
Nice work Dave!
Re: MY JEEP BUILD THREAD [Re: Hooligan] #1061747
03/03/14 10:45 PM
03/03/14 10:45 PM
Tampa
Tampa
Thanks, Steve!
I installed the gas pedal, and trimmed and installed the Lokar throttle cable. After 2-1/2 years, I have a working gas pedal again!
The Crow 5 point safety harnesses came in today. Since the basic color theme of the Jeep is red and black, I went with black belts, black anodized hardware, and red sewn-in shoulder belt pads.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061748
03/03/14 11:51 PM
03/03/14 11:51 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Where did you get the screen for the venting ?
I am truckless..
Re: MY JEEP BUILD THREAD [Re: 340SHORTY] #1061749
03/04/14 01:22 AM
03/04/14 01:22 AM
Tampa
Tampa
At the mall, of course! Screens R Us, located right next to the food court.
I got it at mcmaster.com
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061750
03/04/14 01:26 AM
03/04/14 01:26 AM
Tampa
Tampa
Picked up an MSD Blaster 2 ignition coil and installed it tonight, along with the finest Taiwan chrome coil bracket. I have a hankerin' to paint it black. Kinda crowded back there, and the only way it would fit comfortably was to bolt it down with a threaded spacer, along with a small flat bracket for support.
You know its getting down to the wire when I'm showing small stuff like this!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061751
03/04/14 01:38 AM
03/04/14 01:38 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Looks great Dave. With the HOT Florida temps you may want to run that carb on a isolated spacer.
Re: MY JEEP BUILD THREAD [Re: NITROUSN] #1061752
03/04/14 01:46 PM
03/04/14 01:46 PM
Tampa
Tampa
Thanks, Pete. You make a good point. However, the carb is temporary. I plan to change over to a self learning EFI setup early next year.
