Re: MY JEEP BUILD THREAD
[Re: 340SHORTY]
#1061740
02/10/14 05:01 PM
02/10/14 05:01 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
that will help get it over those curbs..
And just in case you need a spot, you can always make a new one. Someone's just going to have to find where you put their car.
[Re: MuuMuu101]
#1061741
02/15/14 01:06 AM
02/15/14 01:06 AM
Posts: 1,845 Tampa
DusterDave
Tampa
DATELINE TAMPA: A MILESTONE HAS BEEN REACHED AT JEEPER DAVE TRAILSPORTS, A WHOLLY OWNED SUBSIDIARY OF DUSTERDAVE MOTORSPORTS..... BODY WORK HAS OFFICIALLY BEGUN!!! I spent a good part of today doing the body work on the front of the grille. As you can see, it needed a lot of attention to get it straight. Since I sanded down to bare metal on some spots, tomorrow I'm going to spray a single coat of epoxy primer, followed by several coats of high build. A final sanding with 320 grit, and this piece will be ready for paint. New tubular fender flares mounted, waiting for their coat of black Monstaliner.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: rickstershemi]
#1061744
02/20/14 01:39 PM
02/20/14 01:39 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Thanks, Rick. Some aftermarket Jeep fenders have the same basic cutout, so I basically stole the idea from them. It's done to let excess engine heat escape.
[Re: DusterDave]
#1061748
03/03/14 11:51 PM
03/03/14 11:51 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Where did you get the screen for the venting ?
I am truckless..
