Re: MY JEEP BUILD THREAD
[Re: DusterDave]
#1061577
02/18/13 01:31 PM
02/18/13 01:31 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
ok....i see two oil filters....one in the original location and the wix on the firewall....are you mess'n with us....????
Love it Dave
Rickster
I was waiting for someone to say something about it!
Before I began building the other 3 primary pipes, I mounted an oil filter in that spot, to mimic the heater blower motor, which sticks out from that hole in the firewall. Mounting the filter there was a visual reminder to keep the pipes clear of it.
Makes perfect sense......somehow....lol
Rickster
[Re: rickstershemi]
#1061578
02/18/13 05:00 PM
02/18/13 05:00 PM
Posts: 15,487 Florida
scratchnfotraction
Love it Dave
Rickster
Rickster
hey that is a kool idea,I am going to mount the NOS 73 mopar filter I have on the heater block off plate just for ?s about why it is there. I shall call it my cabin filter for non a/c trucks.
I was gonna ask Dave but figured it was a remote location for reals.
[Re: DusterDave]
#1061582
03/04/13 03:44 PM
03/04/13 03:44 PM
Triple Threat
Renton Washington
Assuming your header place is the same as mine in their formula, this is what Gray Ice looks like when new. Over time they become a satin finish as advertised.
[Re: DusterDave]
#1061586
03/14/13 10:14 PM
03/14/13 10:14 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Made some progress on the rear bumper. She's a real swinger. My next acquisition is going to be this front bumper. It's a newly designed unit that just hit the market.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: Bad340fish]
#1061591
03/16/13 07:49 PM
03/16/13 07:49 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Dave I have had two friends who have broken those trailer spindles as tire swing outs, so keep an eye on them. I think they determined that it was due to the weld being to close to the bearing surface and messing with the hardness?
Not trying to scare you just making you aware of a possibility. Both we were well supported when closed also.
I like the latch at a 45, that should hold it nicely. The bumper on my cherokee has the same style latch but its on top of the swingout and hooks on the forward side of the stop/locator. It works well but I think the 45 degree idea would hold it even more stable.
I appreciate your concern and the advice, but this shaft is beefier than the average trailer spindle. In addition, it is not welded on, just a couple of tack welds at the base is all it needs, so the hardness of the shaft isn't affected. The shaft slides into that machined sleeve, and its the sleeve that is welded to the bumper. Once fully welded in, the sleeve shrinks a tiny bit, and locks the shaft in place, hence only a couple tacks added to the base of the shaft just make sure it never moves.
[Re: DusterDave]
#1061592
03/17/13 07:59 PM
03/17/13 07:59 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
Theirs was burned right to the spindle....probably the cause!
68 Barracuda Formula S 340
