Page 19 of 55 1 2 17 18 19 20 21 54 55
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061393
08/21/12 11:56 PM
08/21/12 11:56 PM
Tampa
DusterDave Offline OP
Tampa
Yep, 15 miles NW of Tallahassee. I thought about the shipping cost but I guess it would still be cheaper than the gas. Might couple it with a trip to Ocala or Old Town. I'll contact you directly and let the thread stay on topic.
Thanks Dave for the intro to Dan. Sorry for the mini jacking.
No problem, Kevin. And, you're welcome.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061394
08/22/12 12:52 AM
08/22/12 12:52 AM
Delray beach, Florida
P
Performance Only Offline
P
Dave,
i really, really like that color blue. great choice. i don't see many jeeps that color but the copper is all too common.
Kevin, let me know if there's anything we can help you with and thanks for the compliments along the way.
machine shop owner and engine builder
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061395
08/22/12 07:25 PM
08/22/12 07:25 PM
Tampa
Tampa
Dave,
Thanks, Dan. Great minds think alike. I have a strange feeling that copper will be a fad color, kind of like green was in the 1970's. I don't know why this blue is so uncommon. I guess the factory figured most people wanted red, green or black Jeeps.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061396
08/22/12 09:04 PM
08/22/12 09:04 PM
P
P
Dave,
i'll see if i can post some pics later, but your block was bored and honed today, ran through the jet washer, brushed, scrubbed, etc. tomorrow we start the process of caging bearings and getting on with the build. shouldn't be long now.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061397
08/22/12 10:25 PM
08/22/12 10:25 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Dan, PM sent
Ya'll gotta quit talking bad about the copper you're giving me a complex, my AAR is FK5.
Careful, your character's showing!
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061398
08/22/12 11:31 PM
08/22/12 11:31 PM
Tampa
Tampa
Dan, PM sent
You own a AAR Cuda? Now you made us jealous!
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061399
08/22/12 11:33 PM
08/22/12 11:33 PM
Tampa
Tampa
Dave,
Hot-diggity!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061400
08/23/12 10:32 PM
08/23/12 10:32 PM
P
P
Dave, here's a picture of the probe readouts. this one is a picture of the blueprint spec. for bore locations on the left side. (drivers side)
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061401
08/23/12 10:35 PM
08/23/12 10:35 PM
P
P
in this picture you'll notice i've checked the box to show the actual difference of the bores locations from the blueprint specs. these bores are incredibly close. someone at Chrysler did a fantastic job on this block.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061402
08/23/12 10:39 PM
08/23/12 10:39 PM
P
P
here's the passenger side bluprint spec.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061403
08/23/12 10:44 PM
08/23/12 10:44 PM
P
P
and here's the actual difference. this is without a doubt the closest to spec block i've encountered so far.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061404
08/23/12 10:48 PM
08/23/12 10:48 PM
P
P
here's some random pictures of the block as i was caging the mains to check and correct oil clearances, install some frost plugs, etc. etc.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061405
08/23/12 10:58 PM
08/23/12 10:58 PM
P
P
here's another one
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061406
08/23/12 11:04 PM
08/23/12 11:04 PM
P
P
and the last one for now. i didn't bring the sonic sheet home or i'd post it for you. maybe tomorrow.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061407
08/23/12 11:16 PM
08/23/12 11:16 PM
Tampa
Tampa
Good stuff, Dan! Man, we saw one extreme to the other with two engine blocks!
I have a question...remember how the ARP main bolts didn't fit the first block? Do they fit this block correctly? I'm only asking because the main bolts in the picture appear to be the old bolts.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061408
08/23/12 11:31 PM
08/23/12 11:31 PM
P
P
No, they didn't fit this one either. the bolt holes in the block aren't deep enough, and even if they were the last thread of the bolt would be at the first thred of the block, even with the washer in place.
i think with all things considered, the stock bolts will handle the job just fine. i have a 340 and 2 360 blocks sitting here i'm working on and those caps are taller than those of the 318 block.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061409
08/24/12 09:20 AM
08/24/12 09:20 AM
mopar346 Offline
mopar346  Offline
Long way from a grease monkey!
What did you think the 346 was for? I have other stuff too, including a 84 CJ I mentioned earlier, 360 NP435 and doing the Toyota axles.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061410
08/24/12 10:01 PM
08/24/12 10:01 PM
P
P
not too much to add here today. here's a picture of the clearance notch needed at the bottom of the cylinders for connecting rod clearance.
aside from that, all the bearing oil clearances are adjusted and all the mock up work is done. one last cleaning and then the final assembly begins.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061411
08/24/12 10:10 PM
08/24/12 10:10 PM
Tampa
Tampa
aside from that, all the bearing oil clearances are adjusted and all the mock up work is done. One last cleaning and then the final assembly begins.
Cue the dancing banana and the rocker!!!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061412
08/24/12 10:26 PM
08/24/12 10:26 PM
P
P
i'm glad you cued the rocker. just a couple more years of this and i'll be spending most of my time in a different kind of rocker.
