Page 14 of 55 1 2 12 13 14 15 16 54 55
Re: MY JEEP BUILD THREAD [Re: tpabayflyer] #1061293
05/06/12 09:26 PM
05/06/12 09:26 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Thats funny I was reading through this thread and was just gonna post that very comment!
I think I read that a single 3 1/2 pipe flows the same as a 2 1/2 dual setup?? Looks mean so far!!! TBF
Re: MY JEEP BUILD THREAD [Re: tpabayflyer] #1061294
05/06/12 09:36 PM
05/06/12 09:36 PM
Tampa
DusterDave Offline OP
Tampa
Some random pics from yesterday's temporary engine/trans install, in preparation for fabricating the exhaust system. Can't do any more until my rear sump oil pan gets here. I have no idea what I'm going to hang the pipes to, or how. I'd prefer to mount them to the frame instead of the tub.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MY JEEP BUILD THREAD [Re: tpabayflyer] #1061295
05/06/12 09:47 PM
05/06/12 09:47 PM
Tampa
Tampa
Hey Mark, Nick and I are heading out to Performance Only in Vero Beach on the 23rd to drop off the engine parts! If you are off that day and want to join us, let me know!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061296
05/07/12 10:28 PM
05/07/12 10:28 PM
I did some work on a friend's AMX with a 390.
They're a very neat little motor.
I do recall putting in an oiling system that oils the front timing chain a little better. It's basically copper tubing that's plumbed in and crimped on the end to "drip" onto the chain. Simple concept but it works.
360's are good, 390's are better and 401's are badass!
Re: MY JEEP BUILD THREAD #1061297
05/20/12 01:30 PM
05/20/12 01:30 PM
Tampa
Tampa
I finished fabbing up the front half of the exhaust system. I'll drop it down later on today and weld it up.
I'll build the back half of the system when the engine and trans are in for good. For now though, the engine and trans need to get hoisted out of there today, because next week I'm taking all the engine parts down to Performance Only.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061298
05/20/12 09:43 PM
05/20/12 09:43 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Nice, maybe a little tight, but probably no worse than some of the stuff in my shop. I was sitting here wondering how you were gonna do the front drive shaft anf it hit me, it's a YJ.
So far so good, cant wait to see the next update.
Careful, your character's showing!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061299
05/21/12 10:12 AM
05/21/12 10:12 AM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I'm really looking forward to the engine portion of this as I am very seriously contemplating a very similar build. Sould be a little torquer!
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061300
05/21/12 04:49 PM
05/21/12 04:49 PM
Tampa
Tampa
Thanks. Its tight in just one spot near the trans, as seen in one of the pics.
Re: MY JEEP BUILD THREAD [Re: Jwilli500] #1061301
05/21/12 04:51 PM
05/21/12 04:51 PM
Tampa
Tampa
That's what I'm looking for in this engine, truck loads of midrange GRUNT!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061302
05/21/12 05:50 PM
05/21/12 05:50 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I see you have great taste when it comes to mufflers ..
I am truckless..
Re: MY JEEP BUILD THREAD [Re: 340SHORTY] #1061303
05/21/12 07:45 PM
05/21/12 07:45 PM
Tampa
Tampa
Great minds think alike.
They are the same 3-1/2" mufflers I used on my old Duster.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061304
05/21/12 09:13 PM
05/21/12 09:13 PM
Lehigh Acres, Florida
rickstershemi Offline
Looking great Dave.....same meticulous fabrication as usual
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061305
05/22/12 07:51 AM
05/22/12 07:51 AM
Tampa
Tampa
Rickster
Thanks Rick. Having built just this small amount of exhaust, I already have gained a greater respect for anyone that builds their own set of headers.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061306
05/24/12 08:17 PM
05/24/12 08:17 PM
Tampa
Tampa
Alright, the engine parts have been delivered to Dan at Performance Only. After the meet 'n greet, and bull session, we went out for lunch at a nice sports bar called Duffy's, and shot the breeze some more, talking about what will be done with the engine. In addition to the machine work and his usual brand of meticulous checking, correcting, and cam selection, Dan is also going to assemble the engine.
It was good to hang out with my friend Dan again. And, since Dan is the Allstate of the engine building world, I feel I'm "in good hands".
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061307
05/27/12 11:31 PM
05/27/12 11:31 PM
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061308
06/08/12 05:31 PM
06/08/12 05:31 PM
Tampa
Tampa
Not much actual progress to report. I've been buying lots of engine parts and having them shipped to Performance Only.
I finally got around to laying down some coats of epoxy primer on the fuel tank and transmission skid plates. I found an awesome, super tough, industrial-grade epoxy primer. Its made by Dupont, and its called Colar 2.1 ST. It is so thick, the label describes it as High Solids Epoxy Mastic. It can be brushed, rolled, or sprayed. It needs to be reduced 10-15% in order to spray it. Still, I had to use a gun with a 1.7mm tip in order for it to spray. I tried my 1.4, but that didn't work. Its designed to go on with a high film thickness, and it doesn't lay down smooth. It dries to a satin finish, and leaves a bit of a light texture, which looks good to me on the skid plates. The guy at the auto paint store told me this primer is used on offshore oil platforms, which is probably the harshest environment for coatings, so it should do a great job protecting my skid plates. Best of all, its relatively inexpensive.
Here's the rundown on the 318 stroker engine specs:
'83 318 block, bored .030 over
NOS magnum heads, stock
Scat 4" cast stroker crank
Eagle SR rods
KB Icon Forged dished pistons (comp. approx. 9.4:1)
Total Seal rings
Comp Cams hyd. flat tappet cam: .516 lift, 239º/246º dur. @ .050
Professional Products air gap dual plane intake manifold
Quick Fuel Slayer 600 cfm carb
Melling HV oil pump
MP rear sump truck oil pan
Pro Gear timing chain set
She's gonna climb hills like a billy goat on steroids!!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061309
06/08/12 10:03 PM
06/08/12 10:03 PM
mopar346 Offline
mopar346  Offline
Awesome wrok.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061310
06/14/12 11:26 PM
06/14/12 11:26 PM
Delray beach, Florida
P
Performance Only Offline
P
getting a little work done on the engine
machine shop owner and engine builder
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061311
06/14/12 11:28 PM
06/14/12 11:28 PM
P
P
another
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061312
06/14/12 11:32 PM
06/14/12 11:32 PM
P
P
time to spin the crank and drill some holes.
