Page 12 of 55 1 2 10 11 12 13 14 54 55
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061253
03/11/12 05:21 PM
03/11/12 05:21 PM
Tampa
DusterDave Offline OP
Tampa
After a week of evenings and most of this weekend, the frame is finally ready for a couple coats of paint. All it needs is a final wipe down. I added two pieces of steel to the frame. I added the crossmember for the anti-wrap ladder bar, and I cut out the stock sheet metal rear bumper mount, and replaced it with a piece of 4" x 1.5" rectangular steel, with threaded inserts for mounting the bumper. I'm going to be hanging a swing-out spare tire mount with a 100 lb. wheel/tire combo, so I felt it needed beefing up. Back to the garage to lay down the paint!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061254
03/11/12 07:10 PM
03/11/12 07:10 PM
Tampa
Tampa
Here it is, after 2 coats.
Here's a close-up of the color. Basically, its a gun metal gray metallic.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061255
03/13/12 11:15 PM
03/13/12 11:15 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Sweet, looking forward to seeing your anti-wrap set up.
Careful, your character's showing!
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061256
03/14/12 01:21 PM
03/14/12 01:21 PM
Tampa
Tampa
One page back, I show a pic of the anti-wrap ladder bar and the crossmember. In the above pic, you can see the brackets tack welded to the rear axle. No pic of the whole setup in place yet. I need to wait until the Jeep is fully assembled, and sitting at ride height.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061257
03/14/12 11:49 PM
03/14/12 11:49 PM
mopar346 Offline
mopar346  Offline
Got it.
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061258
03/18/12 05:44 PM
03/18/12 05:44 PM
Tampa
Tampa
I de-burred the shackle plates, and rattle canned a coat of satin black on them and the leaf springs. Bolted them up to the frame for the final time. I should be getting the finished front axle back from the axle shop this week. I would have gotten it back last week, but the knucklehead forgot to order the Detroit Locker.
I've decided to hold off on rebuilding the rear axle until near the end of the build, and instead, focus on the engine build as the next order of business. As previously stated, I've chosen Dan at Performance Only to take care of the engine work.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061259
03/18/12 08:24 PM
03/18/12 08:24 PM
mopar346 Offline
mopar346  Offline
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061260
03/18/12 09:15 PM
03/18/12 09:15 PM
Lehigh Acres, Florida
rickstershemi Offline
LQQKIN Great Dave
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061261
03/18/12 10:13 PM
03/18/12 10:13 PM
Tampa
Tampa
Kevin and Rick, thanks!!
I'm looking forward to working with my friend Dan on the engine. That will probably begin sometime in June, hopefully.
In the meantime, to keep me busy, I've ordered an RCI 15 gallon aluminum fuel cell. Later this week, I'll fab a combination skid plate/mount for it, make it out of steel diamond plate for strength, and run a length of #8 braided line to the front.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061262
03/20/12 07:53 PM
03/20/12 07:53 PM
Tampa
Tampa
The brown truck visited my house today. I love logistics!!!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061263
03/20/12 09:24 PM
03/20/12 09:24 PM
mopar346 Offline
mopar346  Offline
Are you gonna leave the blocks or devise another way of mounting? Just asking?
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061264
03/21/12 07:42 AM
03/21/12 07:42 AM
Tampa
Tampa
The blocks are temporary. I'm going to fill the fuel cell with helium.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061265
03/21/12 08:17 AM
03/21/12 08:17 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Are you going to have enough traction with the tank full of Helium??
I am truckless..
Re: MY JEEP BUILD THREAD [Re: 340SHORTY] #1061266
03/21/12 05:50 PM
03/21/12 05:50 PM
Tampa
Tampa
With 37's locked front and rear, traction won't be an issue!
Re: MY JEEP BUILD THREAD [Re: 340SHORTY] #1061267
03/21/12 11:05 PM
03/21/12 11:05 PM
mopar346 Offline
mopar346  Offline
No need for traction he can float across.
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061268
04/01/12 06:51 PM
04/01/12 06:51 PM
Tampa
Tampa
I got the front axle back from the shop. It's a hell of a lot heavier now than when I dropped it off to them! They did a complete rebuild, and threw in Superior axles, a Detroit Locker, and Spicer 4.55 gears.
I gave it a coat of Hammerite black paint, but I laid it on a little heavy on the axle tubes and created some drips. I'm going to sand them out and touch it up.
I made the frame a roller again. The front axle and suspension are on for good this time.
The fuel cell mount/skid plate is almost finished. I just need to weld on some tabs. I'm going to add 4 rivet nuts to the crossmember, so I can bolt down the front of the skid plate. The back of the skid plate is attached to the frame with a pair of 1/2-13 bolts.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061269
04/01/12 09:52 PM
04/01/12 09:52 PM
the drag-link appears to be hitting the front spring segment...?????
Looks Killer
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061270
04/01/12 11:11 PM
04/01/12 11:11 PM
Tampa
Tampa
Looks Killer
Rickster
Thanks, Rick. There is actually a good 3/8" of clearance between the top of the leafs and the bottom of my makeshift tie rod. When the frame and suspension sees the full weight of the body, drivetrain, etc., the leafs will flatten, and that clearance will increase.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061271
04/02/12 11:02 AM
04/02/12 11:02 AM
mopar346 Offline
mopar346  Offline
Very nice, are you going to be able to drop the tank without removing the tub, just a thought if you haven't considered it. Again, I sure your're ahead of it but make sure you have full travel up and down on the draglink clearance.
Great work.
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061272
04/02/12 01:37 PM
04/02/12 01:37 PM
Tampa
Tampa
Great work.
Thanks. Yep, already thought about it, and yes, the tank can be dropped.
