Page 10 of 55 1 2 8 9 10 11 12 54 55
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061213
01/11/12 12:06 PM
01/11/12 12:06 PM
scratchnfotraction Offline
YOU DON'T UNDERSTAND THIS JEEP WILL NOT BE SUBJECTED TO THE RIGGORS OF OFF-ROAD USE
Rickster
Wow, Rick. Did somebody have a half price sale on oversized emoticons???
I haven't talked about how I plan to use my Jeep, but lots of other people have.
Just kidd'n.....I know you plan to take it off-road.....most car shows I have been to are mostly on grass....lol
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061214
01/11/12 09:56 PM
01/11/12 09:56 PM
Tampa
DusterDave Offline OP
Tampa
Rickster
Rickster
Well Rick, its clear that you have experience with taking your Jeep off-road.... and there it is, PARKED ON GRASS!!! At least you parked it on the tall grass, for more visual effect!!!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061215
01/11/12 10:52 PM
01/11/12 10:52 PM
Lehigh Acres, Florida
rickstershemi Offline
Rickster
Rickster
Never even got the tires dirty....lol Actually just sold it $10K bought it in 01 new for $10.3K not bad
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061216
01/12/12 12:03 AM
01/12/12 12:03 AM
Tampa
Tampa
Yeah, I noticed the tire treads looked totally clean! It's as if you had it air lifted to that spot via helicopter!
You bought it at a great price. New Jeeps today go for more than double that amount.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061217
01/12/12 12:08 AM
01/12/12 12:08 AM
It was the cheapest model you could buy at the time.....Sport 4-banger 5-speed w/zero options
Had only 37k on the clock when I let it go
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061218
01/16/12 12:50 AM
01/16/12 12:50 AM
Tampa
Tampa
Got some work done this weekend on the Jeep. The 727 4x4 trans has a tall and quite beefy cast-in mount on the shorty tailstock. The tallness of it was positioning the transfer case higher than I liked. So, I did some modifications to the skid plate, in an effort to lower the t-case, which in turn, improves both the front and rear driveshaft angles. I also made a pair of 1" thick skid plate spacers. The total result is a 2.25" drop at the trans mount.
Saturday, I visited Moparts member "scratchinfotraction". He sold me a smallblock power steering setup that I was needing for the 318. Actually, he was kind enough to offer it to me for free. It was a very nice gesture, especially since we had never met before, but I had to do the right thing. Mike's a nice guy, and a cool cat. He's got a lot of great stories, especially about his buddy named Ace!
The PS setup was complete, except for a triangular bracket. It was a simple piece, so I made one out of 3/16" steel plate.
I made some cardboard templates of the engine mount brackets. I've transferred them to a piece of 3/16" thick steel plate. Tomorrow night, I'll cut them out with the plasma cutter.
My front shock hoops are on the way, should be here by mid week. I need to cut out the old shock mounts that you see in the pic.
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061219
01/16/12 11:04 PM
01/16/12 11:04 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Dude you got skills, it is coming out nicely.
Careful, your character's showing!
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061220
01/17/12 12:20 AM
01/17/12 12:20 AM
Tampa
Tampa
Thanks. Just enough skills to be dangerous. I'm a little embarrassed at the nasty, long weld on that skid plate drop section. My welder wasn't feeding wire in a consistent manner, and was basically creating a sputtering weld bead. I opened the side of the welding machine, and saw that it was just about out of wire. Threw a new roll on, and I was back in business.
Once I get the engine mount brackets welded on, I need to turn my attention to building an anti-wrap ladder bar setup.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061221
01/17/12 12:22 AM
01/17/12 12:22 AM
mopar346 Offline
mopar346  Offline
I look forward to it.
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061222
01/20/12 10:44 AM
01/20/12 10:44 AM
Tampa
Tampa
I designed and fabricated some engine mounting brackets. When I yank the engine and trans out tomorrow, these will get welded to the sides of the frame rails. The last thing that needs to get welded to the frame are the anti-wrap ladder bar crossmember mounts. Once that's done, I'll get it back down to the bare frame again, and paint it.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061223
01/20/12 10:20 PM
01/20/12 10:20 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
they look good but I would have at least tacked them while they where bolted to the motor with it in the correct place.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: MY JEEP BUILD THREAD [Re: dusturbd340W5] #1061224
01/20/12 10:38 PM
01/20/12 10:38 PM
Tampa
Tampa
You mean, something like this?
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061225
01/21/12 06:43 PM
01/21/12 06:43 PM
mopar346 Offline
mopar346  Offline
Looks like crap, don't know why you wasted your time. I will be down tomorrow to get that eye sore out of your way, wont even charge you to haul it off cause that's the kinda guy I am.
AND since you will know have no use for all that stroker stuff I can put it in the back of my truck to save you the trouble of hauling it off, you'll have to load it though, I cant be expected to do everything!
OK, so I'm on crack. It looks great and I assume slide in and out of the mounts perfectly.
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061226
02/01/12 12:49 AM
02/01/12 12:49 AM
Tampa
Tampa
You're right, it does look like crap. But don't worry, she'll shine up nice one of these days!
I've begun to install shock hoops on the front, and I have no idea what the best shock angle is. I have my home made shock fixture laid back 3º. When looking at the shock from the front, its perfectly vertical.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061227
02/01/12 12:51 AM
02/01/12 12:51 AM
Tampa
Tampa
Made a crossmember for the anti-wrap ladder bar setup. It will be welded on the bottom of the frame, just behind the skid plate. I'll be making the ladder bar this weekend.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061228
02/02/12 12:06 AM
02/02/12 12:06 AM
mopar346 Offline
mopar346  Offline
Is the ladder crossmember gonna hang any lower than the factory crossmember? Your welding blows me away.
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061229
02/02/12 09:51 AM
02/02/12 09:51 AM
welding and the craftsmanship
are you makeing those brackets with the radius cut for the axle tube?
shock hoops look good,but the shock rod is gonna ride ruff
Re: MY JEEP BUILD THREAD [Re: scratchnfotraction] #1061230
02/02/12 07:50 PM
02/02/12 07:50 PM
Tampa
Tampa
Thanks guys, but I'm really just a hack welder. I need to work on making consistently nice welds. I recently switched to .025 wire, and that has made a big improvement in the quality of my welds. Lots of practice has helped, too.
scratchnfotraction, no, I bought the ladder bar brackets. I was going to make my own, but when I saw that Applied Racing (ART), which is close to where I work, sells them for less than $10.00 a piece, I didn't see any benefit to making them.
And, just in case someone got the wrong idea, I bought the shock hoops, too. If I had access to a bender, I would have made them.
I picked up the final bits of hardware to make my anti-axle-windup ladder bar. The round thing is a flex joint, also known as a Johnny Joint. It will be welded to the front of the ladder bar.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061231
02/02/12 09:04 PM
02/02/12 09:04 PM
Kissimmee Fl.
Kissimmee Fl.
JMO but .025 is to small for frame work and such I was told by a cert. welder when I started my cage not to use any thing smaller than .030 and he would have preferred .035.
Re: MY JEEP BUILD THREAD [Re: dusturbd340W5] #1061232
02/05/12 06:15 PM
02/05/12 06:15 PM
Tampa
Tampa
A productive weekend. Yesterday, I located and tack welded the front shock hoops and lower shock mounts into place. They will give me 4" more travel than the factory towers.
Today, I made the anti-wrap ladder bar.
