crane roller lifters #1060358
08/23/11 04:25 PM
08/23/11 04:25 PM
nc
E
earthmover Offline OP
E
nc
i was reading in andys book about roller lifters with the oil hole drilled directly at the main gallery would cause some excessive internal oil flow problems...i see the crane roller lifters has this oil hole..now my ? is is this without lifter bushing or with lifter bushing i plan to have me block done with the bushing ..
Re: crane roller lifters [Re: earthmover] #1060359
08/23/11 05:52 PM
08/23/11 05:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think he is talking about a NON bushed block
but you might PM him OR he might see this
Re: crane roller lifters [Re: earthmover] #1060360
08/23/11 06:03 PM
08/23/11 06:03 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
The Crane roller lifters are designed to work with standard blocks. You can certainly bush the lifter bores if necessary for your application, and they will still be good. Regards, Chase
Re: crane roller lifters [Re: cknight] #1060361
08/24/11 01:12 AM
08/24/11 01:12 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You can bush the lifters and still have pressurized oil from the lifter galley
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
