Phoenix or other 14x32's #1059581
08/22/11 05:37 PM
08/22/11 05:37 PM
Newark, OH
Hunted Duck Offline OP
Newark, OH
I am having to take off my first pair of phoenix's that have 200+runs on them. 1st question is phoenix tires still in selling tires? I can get a set from jegs. Is there a better lasting tire out there. These have been on the car since 2008. My rollout on the phoenix were 102.5 when I first put them on and just measured again and they were 101. Thanks for the input.
Re: Phoenix or other 14x32's [Re: Hunted Duck] #1059582
08/22/11 05:45 PM
08/22/11 05:45 PM
gregsdart Offline
gregsdart  Offline
They are now owned by Coker Tire I believe. Call them and ask if they still use the same rubber compound. If so, I'd put another set on with a life span like that.
Re: Phoenix or other 14x32's [Re: gregsdart] #1059583
08/22/11 06:36 PM
08/22/11 06:36 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
I used then on my car and I loved them.... but I also used them WAYYY back when they were still firestone. tried Goodyears. they were so so. cant fit a Hosier of the same size. too much section width for my car.
I would go with them again if I was you. or me!
Re: Phoenix or other 14x32's [Re: Hunted Duck] #1059584
08/22/11 06:38 PM
08/22/11 06:38 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We have always had MANY runs on Phoenix,and also Firestone when we ran them.They will hook when the cords are showing!
Nautilus Racing-
Re: Phoenix or other 14x32's [Re: Chris2581] #1059585
08/22/11 06:42 PM
08/22/11 06:42 PM
Newark, OH
Newark, OH
Mine were hoooking good till this last weekend. I was having to do a pro stock burnout or its wasn't hooking. But in defense of the tires there isn't much if any indecator left. I have a bad new set of phoenix's in the garage. All I have to do is soap them up and mount them.
Re: Phoenix or other 14x32's [Re: Hunted Duck] #1059586
08/23/11 01:05 AM
08/23/11 01:05 AM
Taylor, Michigan
1BadLiLCharger Offline
Taylor, Michigan
I was very happy with my Phoenix slicks. I noticed the other day when I was under the car that the date they put on them when originally mounted was in 2007. Problem is, I wanted another set at the end of June, and the earliest date I was hearing from all the stores was mid August, well now I'm hearing late September early October....I run the 31.25 X 12.2 - I can't wait, I'm going back to Goodyear 14 X 32's (D1984) - they lasted pretty long on the '81 Charger, they're just so freakin' heavy.
Re: Phoenix or other 14x32's [Re: 1BadLiLCharger] #1059587
08/23/11 01:50 AM
08/23/11 01:50 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm using MT 32x14's here with the stiff sidewall. i race 12 meetings a year & get near on 2 seasons out of a set. admittedly they're going off by the end of the second season.
Re: Phoenix or other 14x32's [Re: rebel] #1059588
08/23/11 10:55 PM
08/23/11 10:55 PM
Newark, OH
Newark, OH
I went with the phoenix's. They were great the first time around so I figured I would go with them again. Just hoping the don't leak as much as the last set. Thanks for the help guys.
Re: Phoenix or other 14x32's [Re: Hunted Duck] #1059589
08/23/11 11:12 PM
08/23/11 11:12 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
I've got Phoenix 14x32's and Rick has MT's. Both cars weigh the same and similar 60's
The little old lady from Pasadena is back!
