Measuring for drive snout on 6/71/8/71 #1059321
08/22/11 11:01 AM
08/22/11 11:01 AM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Looking to buy a drive snout for my blower case GMC 8/71,...I would like to do it only once ....after determining where the blower pulleys "sit", how is the snout measured?, from what points?....to determine the correct length to order/purchase, I know shorter is better, because the distance can be made up in spacers, I just don't want to order based on the wrong measuring criteria....
TIA
Mike
Re: Measuring for drive snout on 6/71/8/71 [Re: DAYCLONA] #1059322
08/22/11 05:10 PM
08/22/11 05:10 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
can you put a yard stick on the crank pulley yet?if so measure from the blower case to the yd stk and subtract for the pulley,if you have the blower on that is.
Re: Measuring for drive snout on 6/71/8/71 [Re: DAYCLONA] #1059323
08/22/11 05:39 PM
08/22/11 05:39 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Thanks Mike
Re: Measuring for drive snout on 6/71/8/71 [Re: DAYCLONA] #1059324
08/22/11 07:37 PM
08/22/11 07:37 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i am retired now so i have time to measure things for ya.to be more clear the case where the snout mounts that flat area is where to measure from.i got out and set the timing on mine today[30* locked]
http://www.youtube.com/watch?v=FsVQhHvjuGA
i hope you will be running soon to share some vids also.
Re: Measuring for drive snout on 6/71/8/71 [Re: Clanton] #1059325
08/23/11 10:02 AM
08/23/11 10:02 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Let me add,,,,,,,,,,,depending on what gears are in the blower,there are a few different bolt patterns used.Another expensive learning curve i went through
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Measuring for drive snout on 6/71/8/71 [Re: hemi-itis] #1059326
08/23/11 10:06 AM
08/23/11 10:06 AM
hemi-itis Offline
hemi-itis  Offline
1st pic is the SMALL bolt pattern,this coupler has the multi bolt pattern.
Re: Measuring for drive snout on 6/71/8/71 [Re: hemi-itis] #1059327
08/23/11 01:12 PM
08/23/11 01:12 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Good to know Al,....I too want to avoid buying a bunch of parts I can't use
Mike
