Measuring for drive snout on 6/71/8/71
#1059321
08/22/11 11:01 AM
08/22/11 11:01 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Looking to buy a drive snout for my blower case GMC 8/71,...I would like to do it only once ....after determining where the blower pulleys "sit", how is the snout measured?, from what points?....to determine the correct length to order/purchase, I know shorter is better, because the distance can be made up in spacers, I just don't want to order based on the wrong measuring criteria.... TIA Mike
Re: Measuring for drive snout on 6/71/8/71
[Re: DAYCLONA]
#1059324
08/22/11 07:37 PM
08/22/11 07:37 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
i am retired now so i have time to measure things for ya.to be more clear the case where the snout mounts that flat area is where to measure from.i got out and set the timing on mine today[30* locked] http://www.youtube.com/watch?v=FsVQhHvjuGAi hope you will be running soon to share some vids also.
[Re: Clanton]
#1059325
08/23/11 10:02 AM
08/23/11 10:02 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Let me add,,,,,,,,,,,depending on what gears are in the blower,there are a few different bolt patterns used.Another expensive learning curve i went through
