Re: My next build... need your suggestions
[Re: Jeepmon]
#1059199
08/22/11 02:29 AM
08/22/11 02:29 AM
Posts: 43,289 Bend,OR USA
Cab_Burge
Make it bigger, sell the unknown parts or use them as conversation pieces 4.300 stroke crankshaft, 6.535 rods, custom pistons, actual compression up 13.0 to 1 to but not over the fuel level for the compression your going to use IE race gas 12.5, Methanol 15 to 1 and so on Have a cam ground to meet your goals for ET and weight
[Re: Chris'sBarracuda]
#1059201
08/22/11 05:29 AM
08/22/11 05:29 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Will a stock block last with that sort of power ?. I would sell the short block or keep it as a spare and build something aftermarket to meet your goals. JMO Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Cab_Burge]
#1059204
08/22/11 01:40 PM
08/22/11 01:40 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Ohoi Crankshaft Company 4.250, 4.300 or 4.375 crank costs $700.00 plus shipping, a set of RPM or CAT Steel H beam rods costs $400.00, $600.00 t0 $1000.00 for custom pistons, $350.00 to balance it and your in the higher HP output ballpark, depending on what compression, camshaft and so on. Keep the heads that way they are now and shift it at or below 7000 RPM, deadly bracket combination that will go faster than what you have now
Thanks Cab
[Re: Jeepmon]
#1059205
08/22/11 01:59 PM
08/22/11 01:59 PM
deaks
robin hood country
You have a nice looking car, that runs pretty good numbers now, just have the heads ported and fit a bit bigger cam, that will probably pick you up another 3/10. Mick
[Re: Mr.Yuck]
#1059207
08/22/11 05:36 PM
08/22/11 05:36 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
I have most of the part to make a 511CID you can have the pistons noched for a good valve relief and be almost there. I'll send you the parts for $1300.00 Shipped Crankshaft - 440 Source 4.250" stroke for a 400 block Rods - Eagle 6.535" w/L19 bolts good to 1500HP Pistons - Icon forged 4.375" bore (w/stock valve reliefs) The pistons can be notched for the B-1 valve reliefs. You would still have a pretty good budget left for the small things.
[Re: Jeepmon]
#1059212
08/23/11 03:37 AM
08/23/11 03:37 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
IMHO, the shortblock is basically un-sellable as you describe it, at least to me anyways, unless your willing to virtually give it away. You've got good heads as is, Id personally spend a bit more than the amount you'd hoped and build a big shortblock with an aftermarket block that will last a long long time at 800+, then worry about having the heads ported/more cam in a year or 3 if necessary... If it goes mid-bottom 9's with a 540' or 572' with stockish B1's and a mild cam I bet you'll reap the benefits of easier maintenance, and room for growth in the future. But I always tend to build for the future, much more than the present.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: Al_Alguire]
#1059213
08/23/11 08:58 AM
08/23/11 08:58 AM
Posts: 4,091 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
...if they are still in good shape resue the current piston and go to a 4.25 stroke and new rod anbd have that solved...If those pistons are good that will save you some $$
I agree. I also think with the masses either opt for the -1's or MW Victors and sell the B1 origs. Gotta consider headers into your budget too, these more common heads use common headers. This will achieve your first expressed goal power-wise. I'm not so sure about meeting your budget though.
[Re: Jeepmon]
#1059214
08/23/11 11:44 AM
08/23/11 11:44 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you trust the block, you could build a 512 to go with the B1 heads which should give you the lightest bob weight. Ideal situation is a center counter weight crank with the RB mains, machine the block to fit. That will let the block live longer. Then when it is time you can upgrade to a low deck after market block (KB?)with the same dimensions. That should give you a torque peak around 6200 rpm and allow a shift point at or below 7200 rpm to help with the life of the motor. Converter will need to be loose enough to flash to 6500 in bad air, to make it consistent if you plan on bracket racing. No matter which way you go, the budget will have to increase IMHO. If you choose to stay with a MW port head, it limits you to around 8.80 at 3,000 lbs under IDEAL circumstances. What ever you chose, be sure the way you go will have room to grow to your ultimate goal years down the road. My goal was to be able to run super comp, but the heads and weight of the car don't allow me to get competitive. If I set up the chassis to cut a light, I don't have the Hp to go 8.90 in the heat. If I set up the chassis for best ET, reaction times suffer and my lights will be poor. So the long term game plan is pretty important! Maybe a post on your ultimate goal for the long term is in order, or we could look that over here.
