Cylinder head dowls/pins, are the needed? #1059039
08/21/11 11:17 PM
08/21/11 11:17 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
The machine shop pulled the dowels out of the decks of my block when they did the machine work. I dont have any on hand, do I need them? I can order them from Summit or Jegs.... http://www.summitracing.com/parts/MRG-4375/
I have another block that has them, if I could get them out, I would just use them.
So, do I order them or not?
Laine.
NRCA Member
Re: Cylinder head dowls/pins, are the needed? [Re: Lmopar69] #1059040
08/21/11 11:20 PM
08/21/11 11:20 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Yes you need them.
Most machine shop local to you should have some. Pull them from another block if you need em quick.
Re: Cylinder head dowls/pins, are the needed? [Re: RobX4406] #1059041
08/21/11 11:24 PM
08/21/11 11:24 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Thats what I thought. Thanks for the quick answer. Gotta love this place.
Luckily, Chevy uses the same size, so Im sure the local shop will have them on hand.
Laine.
NRCA Member
