torsion bars #1058795
08/21/11 06:48 PM
08/21/11 06:48 PM
Indiana
65dragnet Offline OP
Indiana
OK guys are the six cyl torsion bars safe and really worth using on a drag car ? My front suspension is not working from being so stiff , car does not transfer well at all.
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: torsion bars [Re: 65dragnet] #1058796
08/21/11 07:30 PM
08/21/11 07:30 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
they are on sb
Re: torsion bars [Re: 65dragnet] #1058797
08/21/11 07:42 PM
08/21/11 07:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
BB you might want to find .940 bars(I think thats the
size)... a light bar will have more stored energy so
it lifts for more distance BUT you still need to have
the travel in your front end... cut the upper bump
stops by at least 1/2
Re: torsion bars [Re: MR_P_BODY] #1058798
08/21/11 08:15 PM
08/21/11 08:15 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
mike, I think they are .8 4 0 bar size, that's what I run on the belvedere
Re: torsion bars [Re: 69CHARGERMD] #1058799
08/21/11 08:38 PM
08/21/11 08:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
So I was off by .100... ... I knew you had a
set but couldnt remember the dia.... what do you want
Doc.... I'm a old fart
Re: torsion bars [Re: MR_P_BODY] #1058800
08/21/11 09:13 PM
08/21/11 09:13 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I was just taking advantage of being able to answer a tech question,,,lol,,usually do more lurking...
The .840 bars are not offered anymore from MP,,Mancini sells a bigger bar,,,i was able to find a pair from a fellow moparts member.
I know some of the after market suspension places have stuff that is close to the .840 bars,,,
I also cut the bump stop down like you mentioned,,and run the calvert shocks up front now.
see ya at Norwalk Mike,,,,
Doug
Re: torsion bars [Re: 69CHARGERMD] #1058801
08/21/11 09:25 PM
08/21/11 09:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
Doug... thats a definite MAYBE... if I get enough work
done on my new ride I'll bring BIG RED down and stay
in it for the weekend but NO car.... I'll be a watcher
and party
Re: torsion bars [Re: 65dragnet] #1058802
08/21/11 09:38 PM
08/21/11 09:38 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Aren't the slant 6's and 318's the same size bar? I saw a chart a few months back it and from what I remember, they're the same.
Try unloading the bars before switching them out. Back off the adjusters so they just barely hold the car off the ground then see how it works.
I ran my roadrunner that way for 10 years because if I ran it at it's normal height the car would slow down over a tenth and felt too stiff on launch!
It was kind of funny.. I was the only one at NTR that ran their mopar that way back then and I got a LOT of questions about doing it. Two years later there were a number of mopars running that way.
My other pictures at the track won't upload so this is it when it was retired(restored) after four years in storage(divorce).
Re: torsion bars [Re: 52savoy] #1058803
08/21/11 09:44 PM
08/21/11 09:44 PM
Indiana
Indiana
Thanks guys I don't know if I can loosen them much more and still have ground clearance ! So the 6 cyl bars are .940 or .840 ? Oh I have 5" of travel just can't get it to use it
Re: torsion bars [Re: 65dragnet] #1058804
08/21/11 10:02 PM
08/21/11 10:02 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
.840 are the light bars.
Re: torsion bars [Re: 52savoy] #1058805
08/21/11 10:14 PM
08/21/11 10:14 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Re: torsion bars [Re: 69CHARGERMD] #1058806
08/21/11 10:21 PM
08/21/11 10:21 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
The smallest MP bar now available is the .920 bar ( for B bodys that is )
http://chucker54.stores.yahoo.net/torsionbars.html
The .840 bar ( if you can find them from MP ) is a race bar..
Not sure what a "6 cylinder" bar size would be,,maybe someone knows...
I have seen some aftermarket suspension places,,,offer bars < .840 and up,,,so you should be able to get what ever you like,,,not sure i would go below the .840 size,,,mine will settle with time,,and i keep the front suspension supported when the car is not in use,,to take the weight off the front.....
Doug
Re: torsion bars [Re: 65dragnet] #1058807
08/21/11 10:31 PM
08/21/11 10:31 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Neither, There .860 and the 318 bars are .880 IMO your car is fast enough to Not use the 6 cyl bars. What bars are you using now?
Re: torsion bars [Re: 69CHARGERMD] #1058808
08/21/11 10:32 PM
08/21/11 10:32 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
I took some measurements awhile back and it seems the 6's and small block B-bodies are .810 or .820
Re: torsion bars [Re: 65dragnet] #1058809
08/21/11 11:37 PM
08/21/11 11:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m running the 6-cyl bars w/descent results.
Re: torsion bars [Re: Sport440] #1058810
08/22/11 06:41 AM
08/22/11 06:41 AM
Indiana
Indiana
Sport 440 ; I'm using the stock 65 Coronet bars now for a b engine. Haven't measured them yet !
Re: torsion bars [Re: 65dragnet] #1058811
08/22/11 06:58 AM
08/22/11 06:58 AM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
I'm running the .820 bars from Firm Feel http://www.firmfeel.com/torsionb_b.htm , and they work awesome. I'm running 29" tall front runners and Afco Double adjustable shocks in the front. With the tall tires I was able to drop the front end and get a lot of travel, also made adjustable bump stops to limit travel as well. Car has been 1.27 60' footbraking.
Curtis
Taking over the World one win light at a time.
Re: torsion bars [Re: afxcoronet] #1058812
08/22/11 05:11 PM
08/22/11 05:11 PM
Indiana
Indiana
awesome ! afxcoronet , I'll check them out. Thanks
Re: torsion bars [Re: 65dragnet] #1058813
08/23/11 12:06 AM
08/23/11 12:06 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
What about the Mopar "Drag Racing" bars? Any difference? Nice post.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: torsion bars [Re: MR_P_BODY] #1058814
08/23/11 12:15 AM
08/23/11 12:15 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
