Re: torsion bars
[Re: 65dragnet]
#1058797
08/21/11 07:42 PM
08/21/11 07:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
BB you might want to find .940 bars(I think thats the size)... a light bar will have more stored energy so it lifts for more distance BUT you still need to have the travel in your front end... cut the upper bump stops by at least 1/2
Re: torsion bars
[Re: 69CHARGERMD]
#1058799
08/21/11 08:38 PM
08/21/11 08:38 PM
MR_P_BODY
mike, I think they are .8 4 0 bar size, that's what I run on the belvedere
So I was off by .100... ... I knew you had a set but couldnt remember the dia.... what do you want Doc.... I'm a old fart
Re: torsion bars
[Re: MR_P_BODY]
#1058800
08/21/11 09:13 PM
08/21/11 09:13 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I was just taking advantage of being able to answer a tech question,,,lol,,usually do more lurking...
The .840 bars are not offered anymore from MP,,Mancini sells a bigger bar,,,i was able to find a pair from a fellow moparts member.
I know some of the after market suspension places have stuff that is close to the .840 bars,,,
I also cut the bump stop down like you mentioned,,and run the calvert shocks up front now.
see ya at Norwalk Mike,,,,
Doug
Re: torsion bars
[Re: 65dragnet]
#1058802
08/21/11 09:38 PM
08/21/11 09:38 PM
Posts: 4,254 State of Fascism
52savoy
State of Fascism
Aren't the slant 6's and 318's the same size bar? I saw a chart a few months back it and from what I remember, they're the same. Try unloading the bars before switching them out. Back off the adjusters so they just barely hold the car off the ground then see how it works. I ran my roadrunner that way for 10 years because if I ran it at it's normal height the car would slow down over a tenth and felt too stiff on launch! It was kind of funny.. I was the only one at NTR that ran their mopar that way back then and I got a LOT of questions about doing it. Two years later there were a number of mopars running that way. My other pictures at the track won't upload so this is it when it was retired(restored) after four years in storage(divorce).
Re: torsion bars
[Re: 52savoy]
#1058803
08/21/11 09:44 PM
08/21/11 09:44 PM
Posts: 716 Indiana
65dragnet
Indiana
Thanks guys I don't know if I can loosen them much more and still have ground clearance ! So the 6 cyl bars are .940 or .840 ? Oh I have 5" of travel just can't get it to use it
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: torsion bars
[Re: 69CHARGERMD]
#1058806
08/21/11 10:21 PM
08/21/11 10:21 PM
69CHARGERMD
KENTUCKY
The smallest MP bar now available is the .920 bar ( for B bodys that is ) http://chucker54.stores.yahoo.net/torsionbars.htmlThe .840 bar ( if you can find them from MP ) is a race bar.. Not sure what a "6 cylinder" bar size would be,,maybe someone knows... I have seen some aftermarket suspension places,,,offer bars < .840 and up,,,so you should be able to get what ever you like,,,not sure i would go below the .840 size,,,mine will settle with time,,and i keep the front suspension supported when the car is not in use,,to take the weight off the front..... Doug
Re: torsion bars
[Re: 65dragnet]
#1058807
08/21/11 10:31 PM
08/21/11 10:31 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Neither, There .860 and the 318 bars are .880 IMO your car is fast enough to Not use the 6 cyl bars. What bars are you using now?
Re: torsion bars
[Re: Sport440]
#1058810
08/22/11 06:41 AM
08/22/11 06:41 AM
Posts: 716 Indiana
65dragnet
Indiana
Sport 440 ; I'm using the stock 65 Coronet bars now for a b engine. Haven't measured them yet !
Re: torsion bars
[Re: 65dragnet]
#1058811
08/22/11 06:58 AM
08/22/11 06:58 AM
Posts: 1,151 Las Vegas
afxcoronet
Las Vegas
I'm running the .820 bars from Firm Feel http://www.firmfeel.com/torsionb_b.htm , and they work awesome. I'm running 29" tall front runners and Afco Double adjustable shocks in the front. With the tall tires I was able to drop the front end and get a lot of travel, also made adjustable bump stops to limit travel as well. Car has been 1.27 60' footbraking. Curtis
Taking over the World one win light at a time.
Re: torsion bars
[Re: afxcoronet]
#1058812
08/22/11 05:11 PM
08/22/11 05:11 PM
Posts: 716 Indiana
65dragnet
Indiana
awesome ! afxcoronet , I'll check them out. Thanks
Re: torsion bars
[Re: 65dragnet]
#1058813
08/23/11 12:06 AM
08/23/11 12:06 AM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
What about the Mopar "Drag Racing" bars? Any difference? Nice post.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
