Well after washing the rings out of 2 motor I figured it was time to tune my carb. I bought a wideband and went to work.
Here's my combo:
493 with Indy-1 heads (around 730hp)
266/271@50 cam /.680 lift 112 lobe sep
11.7:1 compression
4500 stall
4.10 gear
3800lb car
here's what Ihad to due to my Pro-systems 1100 cfm dominator:
main jet 77/ sec jet 92...PVCR .0935...PV 4.5...idle feed .035
transfer slot jets .063...HSAB .029...IAB.076...Int air bleed not used...Intermediate circuit blocked...37 squiters...Idle screw 2 turns out...timing locked at 36.
Idle 15:1 afr
cruise below 2500rpm 14.7-15 afr
cruise above 2500rpm 14.2-14.7 afr
WOT 12.5-13 afr
The car runs and drives perfectly now. The bast part is I will never foul a plug again, or wash the rings out of my motor again
So those of you with a similar combo and running with the dominator might try this.
