SB? Improving oil drain back #1058581
08/21/11 01:18 PM
08/21/11 01:18 PM
Renton Washington
Triple Threat Offline OP
Renton Washington
My current 340 with Edelbrock heads holds a ton of oil up top, its a guarantee that anytime I pull a valve cover oil gets on the headers. Is there any way I can help this or is it just the nature of the beast with these heads?
Any tips or tricks?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: SB? Improving oil drain back [Re: Triple Threat] #1058582
08/21/11 01:38 PM
08/21/11 01:38 PM
SoCal
Brian Hafliger Offline
SoCal
What rocker arms are you using?
Brian Hafliger
Re: SB? Improving oil drain back [Re: Brian Hafliger] #1058583
08/21/11 02:12 PM
08/21/11 02:12 PM
Renton Washington
Renton Washington
1.6 Cranes, This question is for an engine i'm building currently, so everything is apart.
-Dustin
Re: SB? Improving oil drain back [Re: Triple Threat] #1058584
08/21/11 03:02 PM
08/21/11 03:02 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Did i grind some grooves to the spring seats on mine?
Or was it at some other head?
Re: SB? Improving oil drain back [Re: sshemi] #1058585
08/21/11 03:18 PM
08/21/11 03:18 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
#6 external drainback lines to the pan.
You can restrict oil to the rockers. I probably would not do this with Cranes as there are no bearings.
Leon
Re: SB? Improving oil drain back [Re: Leon441] #1058586
08/21/11 03:54 PM
08/21/11 03:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Leon
This is what I would think also... just like doing a
set of B-1 heads.... they hold a ton of oil
