Re: Firecore Dist.
[Re: dare_dude]
#1058430
08/21/11 12:10 PM
08/21/11 12:10 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
I'll say it first. We are retro-fitting the tension clip holding the reluctor to the shaft has been ridng up. Not sure if the customers are installing it correctly after swapping springs or what, but we are addressing the issue. Other than that, great results.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Firecore Dist.
[Re: sunroofgtx]
#1058433
08/21/11 01:42 PM
08/21/11 01:42 PM
Posts: 1,443 central ohio
nss guy
central ohio
on the dist., I changed the springs and closed up the advance slot, it was a little tricky getting the tension clip back in. I've been running it for about a year, timing is rock steady and motor starts easy.
Re: Firecore Dist.
[Re: nss guy]
#1058434
08/21/11 02:16 PM
08/21/11 02:16 PM
sunroofgtx
Cleveland
Small blocks just became available. Vacuum and Ready to Runs for now. Thanks Jim.
