Flexplate bolts/Loctite? #1058332
08/21/11 10:19 AM
08/21/11 10:19 AM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Im running an BB mated to a PG with a flexplate/adapter setup.
Do you use loctite on the bolts when assembling?
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Flexplate bolts/Loctite? [Re: fed] #1058333
08/21/11 10:20 AM
08/21/11 10:20 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I would
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Flexplate bolts/Loctite? [Re: fed] #1058334
08/21/11 10:23 AM
08/21/11 10:23 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I loctite everything except rods, mains, head, studs/bolts.
Re: Flexplate bolts/Loctite? [Re: dusturbd340W5] #1058335
08/21/11 10:23 AM
08/21/11 10:23 AM
michigan
sturmenater Offline
sturmenater  Offline
michigan
yep blue loctite
Re: Flexplate bolts/Loctite? [Re: sturmenater] #1058336
08/21/11 10:30 AM
08/21/11 10:30 AM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
definitely-- blue loctite
i run the same thing--BB w/pg--i "soak" the t/c bolts with red loctite and i still check them before every outing
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: Flexplate bolts/Loctite? [Re: ROSSIO] #1058337
08/21/11 11:44 AM
08/21/11 11:44 AM
Kissimmee Fl.
Kissimmee Fl.
I always use Red myself
Re: Flexplate bolts/Loctite? [Re: fed] #1058338
08/21/11 12:54 PM
08/21/11 12:54 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
don't you have a GM converter?
Uses locking nuts and bolts no lock tite
home of the
Sox and Martin Hemi Duster
Re: Flexplate bolts/Loctite? [Re: HEMIFRED] #1058339
08/21/11 02:06 PM
08/21/11 02:06 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
The converter is treaded.
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Flexplate bolts/Loctite? [Re: fed] #1058340
08/21/11 03:09 PM
08/21/11 03:09 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i use red. when it comes time to remove them, just apply some heat to the bolts & they will come alot easier. stay safe, seeya.
Re: Flexplate bolts/Loctite? [Re: rickraw] #1058341
08/21/11 03:21 PM
08/21/11 03:21 PM
MN
hemidup Offline
hemidup  Offline
MN
"Red" here.
Jerry Williams.
Re: Flexplate bolts/Loctite? [Re: fed] #1058342
08/21/11 03:48 PM
08/21/11 03:48 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I have at least 6 p/g Mopar conversions and none use a threaded converter
home of the
Re: Flexplate bolts/Loctite? [Re: HEMIFRED] #1058343
08/21/11 05:57 PM
08/21/11 05:57 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Treaded boltholes!
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Flexplate bolts/Loctite? [Re: fed] #1058344
08/21/11 06:04 PM
08/21/11 06:04 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Fred's stuff is to cheap to have the threaded converter lugs.
Just picking on you Fred.
My chevy converters are not threaded either. It's because the converter companies are cheap.
Seriously
This guys is really nice.
Leon
Re: Flexplate bolts/Loctite? [Re: Leon441] #1058345
08/21/11 06:30 PM
08/21/11 06:30 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Converter built in Sweden by Danielssonīs.
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Flexplate bolts/Loctite? [Re: fed] #1058346
08/22/11 12:15 AM
08/22/11 12:15 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
My pwr glide converter is threaded to. I use a longer bolt and put a nut on the end, no loctite. On the adapter at the fly wheel, no loctite. I did the last time and had issues getting my allen head counter sunk bolts out. They strip very easy. I just put a new adaptor plate on last week. No loctite. A new adaptor plate kit was 80 bucks.
