Car is surging at the big end of the track...help #1057812
08/20/11 09:54 AM
08/20/11 09:54 AM
Ohio
SteveR Offline OP
SteveR  Offline OP
Ohio
I had my car at the track last night for a test n tune night. Car launches well and runs through 1st gear ok, but in 2nd gear above 4000rpm, and into 3rd it is surging very bad. Only recent change was a swap to a higher volume fuel pump. Anyone have any suggestions?
Here's my combo
73 challenger
0.030 over 360, 9.8:1 compression
0.477 lift cam
Eddy 750 performer carb, air gap intake.
Eddy performer fuel pump (110 gal/hr)
Stock 5/16 fuel line from tank to carb.
Stock electronic ignition
727 auto, 8 3/4 rear w/ 3.55 gear.
Re: Car is surging at the big end of the track...help [Re: SteveR] #1057813
08/20/11 09:58 AM
08/20/11 09:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Lean
Re: Car is surging at the big end of the track...help [Re: MR_P_BODY] #1057814
08/20/11 09:59 AM
08/20/11 09:59 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Beat me to it Mr P
I was gonna say LEAN
Kasey
Re: Car is surging at the big end of the track...help [Re: Moparnut426] #1057815
08/20/11 10:40 AM
08/20/11 10:40 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Mechanical pumps are prone to vapor lock. Insulate your fuel line and spray your pump down with a garden sprayer between passes.
Re: Car is surging at the big end of the track...help [Re: cgall] #1057816
08/20/11 11:05 AM
08/20/11 11:05 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Put the old pump back on, lol.
8.30's @3400 lbs
Re: Car is surging at the big end of the track...help [Re: SteveR] #1057817
08/20/11 11:11 AM
08/20/11 11:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
By chance did you kink (or reduce) the line when you
changed the pump
Re: Car is surging at the big end of the track...help [Re: MR_P_BODY] #1057818
08/20/11 01:57 PM
08/20/11 01:57 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I'd lose the 5/16th fuel line............and the small diameter pick up in the tank for starters.
Re: Car is surging at the big end of the track...help [Re: SteveR] #1057819
08/20/11 02:04 PM
08/20/11 02:04 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
x 22 ... lean. But it is because of low fuel-pressure. You have major fuel-delivery probs.
Re: Car is surging at the big end of the track...help [Re: MR_P_BODY] #1057820
08/20/11 02:55 PM
08/20/11 02:55 PM
Az
Crizila Offline
Crizila  Offline
Az
Lean
Is your fuel pressure gauge located where you can see it when it occurs?
Fastest 300
Re: Car is surging at the big end of the track...help [Re: Crizila] #1057821
08/21/11 01:20 PM
08/21/11 01:20 PM
Ohio
SteveR Offline OP
SteveR  Offline OP
Ohio
No. Only gauge is currently mounted on the engine. I'm looking at adding one inside so I can see it.
Checked the fuel line yesterday and didn't see any kinks. One small section of rubber hose between the frame rail line and pump is soft, so I am going to replace it with a stiffer hose. Could this be collapsing since it is on the suction side of the pump?
Re: Car is surging at the big end of the track...help [Re: SteveR] #1057822
08/21/11 02:13 PM
08/21/11 02:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have seen cheap carb type hose collapse... I like
to use EFI rubber hose... it has a Viton liner in
it so its stiffer... but anything is possible
Re: Car is surging at the big end of the track...help [Re: SteveR] #1057823
08/21/11 02:22 PM
08/21/11 02:22 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Did you increase the inlet line sizing and pickup size inside your fuel tank, if stock with the higher volume pump?
Cavation is a big problem with hi volume pumps.
