Just a reminder to take your time vs. rushing it #1056818
08/19/11 03:36 PM
08/19/11 03:36 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
A few weeks ago I found myself w/ a limited amount of free time available and a burning desire to finish the porting on my "Frankenstein" intake. At that point it had the runner exits rewelded due to some port matching issues w/ the new heads and had been milled by Dwayne Porter to fit properly. Anyway, I fired up the Makita w/ a "fast cut" carbide to open up all that new weld and it was a classic episode of "Man vs. Machine!" because of only having narrow window of opportunity.
Cut to the chase: the end results aren't pretty... and really aren't indicative of the type of work I try to do for myself. And last night as I was removing the intake from the heads mocked-up on the block while trying to check the port alignment, it really bothered me that I did such a freakin' hack job on the intake, simply because I got tired of it taking so long to get the MoPig back together (again).
Will it work? Yeah, but I'd be embarassed to show anybody the intake off the engine because of how crappy it turned out. And short of going through the major (and not inexpensive) hassle of duplicating this particular intake w/ all the welding & porting work, I can't even say if it would have been 2, 10 or 20 HP better had I taken my time. But it really pi$$es me off that this is how it turned out... and that it could (and should) have turned out better if I'd not been in such a rush.
"Learn by other's mistakes!"
Re: Just a reminder to take your time vs. rushing it [Re: BradH] #1056819
08/19/11 03:38 PM
08/19/11 03:38 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
pics or lie
Mopar Performance
Re: Just a reminder to take your time vs. rushing it [Re: moparniac] #1056820
08/19/11 03:50 PM
08/19/11 03:50 PM
BradH Offline OP
BradH  Offline OP
pics or lie
No pics! It looks like my 3-year old did it... well, maybe my 7-year old.
Re: Just a reminder to take your time vs. rushing it [Re: BradH] #1056821
08/19/11 03:54 PM
08/19/11 03:54 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
could it look as bad as the outside of the intake?
Re: Just a reminder to take your time vs. rushing it [Re: sixpackgut] #1056822
08/19/11 04:08 PM
08/19/11 04:08 PM
BradH Offline OP
BradH  Offline OP
Indeed...
Re: Just a reminder to take your time vs. rushing it [Re: BradH] #1056823
08/19/11 04:11 PM
08/19/11 04:11 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
pics or lie
brad I bought an intake way back of eBay just to mess with porting and new I was gonna trash it and tried different stuff on it! no biggie just post a pic! im no allstart intake porter with a flow bench but like to try things myself win lose or draw.... now wheres the pic before the mob comes in
Mopar Performance
Re: Just a reminder to take your time vs. rushing it [Re: BradH] #1056824
08/19/11 04:24 PM
08/19/11 04:24 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Indeed...
naming it Frankenstein from the beginning couldnt have been good for its self esteem and probably just said f it and i doubt there was anything you could do except for taking it on one of those makeover shows
even then, after the show it would probably just let itself go
Re: Just a reminder to take your time vs. rushing it [Re: sixpackgut] #1056825
08/19/11 04:53 PM
08/19/11 04:53 PM
NC
440Jim Offline
440Jim  Offline
NC
Sometimes things take longer than normal/expected. And rushing, forcing, or "trying harder" can result in lesser results.
Today I was helping MJ freshen his 727, mostly to check the sprag when he broke the rear end last year. The car hasn't been driven since. Yes the sprag was rolled, so that got fixed. The rest was in great shape, but I think he only has less than 200 passes since 2004. During the last step of reassembly, I put the pump in without the o-ring to check the input shaft end play. It had none, and the input shaft wouldn't turn by hand either. After spending a hour checking things and putting the clutch packs in and out maybe 5 times it all went together correctly and had the same endplay as before disassembly. I wasn't getting the rear clutch discs to all go on the planetary all the way. We both kept our cools and just kept at it until it was right. But that was an hour longer than normally needed.
Re: Just a reminder to take your time vs. rushing it [Re: 440Jim] #1056826
08/19/11 09:28 PM
08/19/11 09:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Brad I thought you had been taking your time hate to see slow motion
Seriously sorry to hear about the issues. It happens to all of us, especially when projects take so long and time is limited. Now you know why i quit this insanity when the kids were young.
Re: Just a reminder to take your time vs. rushing it [Re: BradH] #1056827
08/19/11 10:56 PM
08/19/11 10:56 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
If its any consolation, a 'rough' port surface on an intake may be faster than a 'smooth' surface port. And the roof matters more than the rest of the port. And then there's always epoxy or JD Weld.. I'd bolt that sucker on and give it a whirl, might surprise you...
Re: Just a reminder to take your time vs. rushing it [Re: Sixpak] #1056828
08/20/11 02:24 AM
08/20/11 02:24 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
You could get some green death from Goodson. It's pretty good epoxy and holds up to gasoline pretty well. Devcon makes better epoxies and they're steel or aluminum specific. That is if you want to build it up and are in a hurry.
Re: Just a reminder to take your time vs. rushing it [Re: sixpackgut] #1056829
08/20/11 09:39 AM
08/20/11 09:39 AM
BradH Offline OP
BradH  Offline OP
Oh, right... "Extreme Manifold Makeover".
Speaking of letting one's self go... is this a good time to mention that my wife recently joined Weight Watchers?
Re: Just a reminder to take your time vs. rushing it [Re: Sixpak] #1056830
08/20/11 09:43 AM
08/20/11 09:43 AM
BradH Offline OP
BradH  Offline OP
The only epoxy I'd trust these days w/ the ethanol-blended pump gas would be Belzona. I already have first-hand experience that Moroso's goes soft and comes off when exposed to alcohol.
My plan at the moment is to try and do some "touch ups", then just run it in whatever form it turns out.
Re: Just a reminder to take your time vs. rushing it [Re: BradH] #1056831
08/20/11 07:02 PM
08/20/11 07:02 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
Hey we all goof up sometimes. Sh*t happens.
you could search out "splash zone" excelent epoxy that works under salt water and can also be applied under water.
Re: Just a reminder to take your time vs. rushing it [Re: bumps440] #1056832
08/20/11 07:27 PM
08/20/11 07:27 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
pics
Mopar Performance
Re: Just a reminder to take your time vs. rushing it [Re: moparniac] #1056833
08/20/11 08:19 PM
08/20/11 08:19 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Everything takes longer than expected. Slow down. Sounds like good advice.
Re: Just a reminder to take your time vs. rushing it [Re: moparniac] #1056834
08/21/11 12:26 PM
08/21/11 12:26 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
pics
