Re: Is wheelbase on 68' Roadrunner vs 68' Coronet same?
[Re: wldgtx]
#1056573
08/19/11 12:18 PM
08/19/11 12:18 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Wild GTX get ready to be shocked... Not identical... The difference is behind the driver the rear floor filler is different, the driveshaft is different, the chrome trim filler on convertibles is different, the rear quarter glass is different... Mismatched parts have cause a few hed scratching moments...
[Re: GMP440]
#1056575
08/19/11 12:33 PM
08/19/11 12:33 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
IIRC the Plymouth WB is slightly shorter (1"?) and it was basically the location of the axle on the leaf springs......not really anything significant; only enough to cause headaches to us restorers 40 years in the future! Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1056577
08/19/11 12:51 PM
08/19/11 12:51 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Chargervert I've had vert trim in different lengths & vert glas that was 1" short... To be honest I don't know the source, it was brought to me as 68 Plymouth vert.. All I really know is it didn't fit & I wasted allot of time trying to make the glass fit... The trim I knew was wrong pretty quick but the glass I spent hours fighting...
[Re: chargervert]
#1056578
08/19/11 12:55 PM
08/19/11 12:55 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
Both the convertible Coronet and Satellites have the same undercarrage structures as the hardtops. They use all the same frame rails,floor pans,the peice under the rear seat,the trunk floor pans,and the inner wheel houses. The only difference is that on convertibles,they added torque boxes front and rear like on Hemi b bodies,and there are stiffining braces inside the rocker panels. other than that the only other difference is that they cut the tops of the wheel housings off and capped them with a flat panel to make room for the retracting roof. I have cut apart a few of each to turn them into Chargers. As far as I know I have never heard of any difference in the rear glass. I have never seen anyone selling B body convertible glass as Plymouth or Dodge specific. I can measure the plymouth glass,but I don't have a Dodge on hand to do so. As far as I know they are the same. Maybe someone sold you some 66/67 peices they are different. the 66/67 vert trim also looks the same,but is different lenghts.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: topside]
#1056580
08/19/11 01:30 PM
08/19/11 01:30 PM
chargervert
The convertibles use the same top frame,bolted in the same location,with the same dutchman panel. The doors and door glass are the same,so I seriously doubt there is any difference in the quarter glass between the 68-70 Dodge and Plymouth verts. Even on the e bodies verts where the floor pan under the rear seat has a two inch difference,uses the same glass and top frame for both Plymouth and Dodge,the difference is in the Dutchman panel on those cars. There is definately no difference in the length of the quarter glass on the hardtops, I have about 50 peices from both Dodges and Plymouths,they are the exact same,all 68-70 B body hardtop glass interchanges except for the Chargers rear window,thats is different for the tunnel back window and the 69 Daytona and 500 use a different window also. The Superbird also uses a different rear window than the standard 68-70 Dodge and Plymouth.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#1056581
08/19/11 04:21 PM
08/19/11 04:21 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
1968 Road Runner 116" wb VS. 1968 Super Bee & Charger 117" wb * 1" difference RR with 8-3/4" has 51-1/2" driveshaft VS. SB/C with 8-3/4" has 52-1/32" driveshaft * 17/32" (.531") difference RR with DANA has 50-3/8" driveshaft VS. SB/C with DANA has 50-31/32" driveshaft * 19/32" (.594") difference
[Re: 6bblgt]
#1056583
08/19/11 04:56 PM
08/19/11 04:56 PM
chargervert
Thats what I thought. It makes sense that the popout windows on the post coupes are specific,as they fit into the openings with a frame and gasket,and the rear quarter panels are shaped different. All the other side glass is the same on the hardtops. The convertibles side glass is also the same for Dodge and Plymouth. It is possible that the Plymouth rear quarter convertible glass that one wild R/T tried to fit in the B body vert that came up an inch short may have come from a 67-69 Barracuda convertible,as it looks almost the same as the B body peices.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: GMP440]
#1056584
08/19/11 05:54 PM
08/19/11 05:54 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
Plymouth = 116", Dodge = 117".
Old, tired, and sometimes broke down. Me, not my car...
[Re: Shoozy]
#1056585
08/22/11 09:45 PM
08/22/11 09:45 PM
Posts: 2,601 Great White North
Furyman
Great White North
There is one other piece of unibody thats different.....the rear leaf spring hanger box.The rear shackle pivot point is moved forward on the Plymouth box.
"Long Live Mopars"
