Re: Some B1 Original pics.........
[Re: supercomp]
#105630
09/01/09 12:27 PM
09/01/09 12:27 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
It''s a 14.1 with 4.375 bore, 4.150 stroke, 0 deck, 62cc chambers, coated exhaust ports and valves. 1050 carb with throttle stop under it. Inake has been port matched only. 2308 bobweight. Cam installed at 109
When you said CNCed i figured they were fully ported..that must explain why your numbers are a bit low. Thats pretty good for just a port match, thats about all mine are too.
[Re: supercomp]
#105631
09/01/09 12:47 PM
09/01/09 12:47 PM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
Looks to me like it went lean on topend...and there is too much time between peak TQ and peak HP plus look at the hp curve... This could be: inefficient ports header tubes wrong length/size collector not right length throttle stop can affect some engines negatively
IMO, the cam could use a tighter lca. I would try tightening the lash and see what happens. See if power goes up or down, or doesn't change. Then get back to us. Post the header tube length's, size, collector length from where the 4 tubes end to the collector opening, and collector size. You'll also need at least 750lbs. open pressure on that cam with B1's. If not, could be slight valve bounce happening, although the A/F doesn't reflect that...do you know why it went up in the 15's????
Brian Hafliger
[Re: Al_Alguire]
#105642
12/08/11 07:43 PM
12/08/11 07:43 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Your stuff flies Al, I would agree the B-1 stuff is stought. Heck my 498" B1-BS makes just under 900HP.
Best Machine and Muscle Motors have done PSO deals and that stuff is real good.
For the money B-1's are hard to beat. <img src="/ubbthreads/images/graemlins/thumbs.gif" alt="" />
<img src="/ubbthreads/images/graemlins/beer.gif" alt="" />
