Page 6 of 8 1 2 3 4 5 6 7 8
Re: Some B1 Original pics......... [Re: supercomp] #105625
08/31/09 12:02 AM
08/31/09 12:02 AM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
A flow bench is just a tool,unless everbody has there heads flowed on the same bench by the same guy there will different numbers. We have seen flow sheets that came with fully ported B-1 heads,reworked buy another B-1 shop with a flow sheet with higher numbers and we flow tested them and get lower numbers. The dyno and ET slip will answer whos are better.
Re: Some B1 Original pics......... [Re: PETE@BESTMACHINE] #105626
08/31/09 10:52 AM
08/31/09 10:52 AM
SoCal
Brian Hafliger Offline OP
SoCal
This is soooo true! I see guys really overdoing the exhaust ports of cylinder heads. I can tell you that my ex. ports you see here are not much larger than OOTB shape. It's the chamber/valvejob/bowl shape a.k.a. the bell curve that is mostly responsible for exhaust flow.
Great big ex. ports have their place, but you'd be surprised how much they can hurt most engines...
Brian Hafliger
Re: Some B1 Original pics......... [Re: PETE@BESTMACHINE] #105627
09/01/09 09:37 AM
09/01/09 09:37 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
500 dynoed 845hp just wondered.
Re: Some B1 Original pics......... [Re: supercomp] #105628
09/01/09 10:27 AM
09/01/09 10:27 AM
SoCal
SoCal
What was the combo? Looks like mid lift #'s on the intake are low too. Are you unhappy with the HP you have?
Tell us more about it...maybe there's a problem elsewhere.
Brian Hafliger
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105629
09/01/09 12:01 PM
09/01/09 12:01 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
It''s a 14.1 with 4.375 bore, 4.150 stroke, 0 deck, 62cc chambers, coated exhaust ports and valves. 1050 carb with throttle
stop under it. Inake has been port matched only. 2308 bobweight. Cam installed at 109
Re: Some B1 Original pics......... [Re: supercomp] #105630
09/01/09 12:27 PM
09/01/09 12:27 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
When you said CNCed i figured they were fully ported..that must explain why your numbers are a bit low. Thats pretty good for just a port match, thats about all mine are too.
Re: Some B1 Original pics......... [Re: supercomp] #105631
09/01/09 12:47 PM
09/01/09 12:47 PM
SoCal
SoCal
Looks to me like it went lean on topend...and there is too much time between peak TQ and peak HP plus look at the hp curve...
This could be:
inefficient ports
header tubes wrong length/size
collector not right length
throttle stop can affect some engines negatively
IMO, the cam could use a tighter lca. I would try tightening the lash and see what happens.
See if power goes up or down, or doesn't change. Then get back to us.
Post the header tube length's, size, collector length from where the 4 tubes end to the collector opening, and collector size.
You'll also need at least 750lbs. open pressure on that cam with B1's. If not, could be slight valve bounce happening, although the A/F doesn't reflect that...do you know why it went up in the 15's????
Brian Hafliger
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105632
09/01/09 02:07 PM
09/01/09 02:07 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Headers are 2 1/8 by 30 with 4" collector 12" long. Heads are fully ported, I was talking about the intake being matched to
the heads. Springs are 310 seat 762 open. The jets were 92s timing 36. I wasn't there when it was dynoed but my
friend said no changes were tried. It even has a belt drive.
Re: Some B1 Original pics......... [Re: supercomp] #105633
09/01/09 02:57 PM
09/01/09 02:57 PM
SoCal
SoCal
Without flowing your heads on my bench, it's really too hard to tell for sure...but your midlift #'s are very low! Header could use a bit longer extension, maybe around 15-16" total length but I'd guess if everything else is right, the heads may be the blame. See I said MAY be the blame...LOL!
Brian Hafliger
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105634
09/01/09 03:41 PM
09/01/09 03:41 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Can't go longer they're on a dragster. I appreciate your opinions.
Re: Some B1 Original pics......... [Re: supercomp] #105635
09/21/09 08:02 PM
09/21/09 08:02 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I guess you would need custom headers made for an A body with a raised deck block.... or does someone make them?
Mopar Performance
Re: Some B1 Original pics......... [Re: moparniac] #105636
12/07/11 06:09 PM
12/07/11 06:09 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I thought I would give one of Brian's posts about B1 heads a bump since several members are going with B1 heads over the Winter. I think Brian did a great job answering lots of questions with some nice pictures. I know when the Daytona hits the track again the 440-1's will be sitting on the shelf and the B1's will be put to use. Thanks Brian and I wish there were more posts like this again on Mopart's but I guess those days are long gone.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Some B1 Original pics......... [Re: pittsburghracer] #105637
12/07/11 07:12 PM
12/07/11 07:12 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
This was a great thread. I wish someone had one like this for B1 PSO's or Predators. Oh well.....
Re: Some B1 Original pics......... [Re: pittsburghracer] #105638
12/07/11 10:40 PM
12/07/11 10:40 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Couldnt agree more.
Tell us about your Combo again John or past B1 engines...
My engine is similar to SuperComp's. 499 Low deck, 14:1 compression, cam is a UltraDyne R8 311...
Couldnt find it on Bullets web site, but has 278° @ 50 and .4544 lobe lift, rockers are 1.75 T&D's so lift is .795 before lash or gross lift.
Not sure on a converter but I would think a 8" 6K would be close. Headers are also Stahl's with 2 1/8 tubes and a 32"-34" length, they are near equal length.
B1 cast single 4 with a 1050 dominator.
Hoping to get this yellow submarine into the 8's. its no heavy weight Id say 2700-2750 lbs with driver.... and 800 HP should Get 'R' Done..
Re: Some B1 Original pics......... [Re: Bob_Coomer] #105639
12/07/11 11:52 PM
12/07/11 11:52 PM
gregsdart Online content
gregsdart  Online Content
Should be able to hit 8.60s with good air at 2750, and a well built 499/B1. 8.80s, piece of cake.
Re: Some B1 Original pics......... [Re: camastomcat] #105640
12/08/11 06:55 PM
12/08/11 06:55 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Predator coming soon!
Re: Some B1 Original pics......... [Re: Biginchmopar] #105641
12/08/11 07:11 PM
12/08/11 07:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As I have said in the past if you cannot make 800hp with a decent set of B1's your doing it wrong. My 67 Valaint was a basic 511 low deck with a good set of B1's that went 9.0's at 150 weiging 3470lbs. My current MC motor seems to run ok
Re: Some B1 Original pics......... [Re: Al_Alguire] #105642
12/08/11 07:43 PM
12/08/11 07:43 PM
Carson City, Nevada
Carson City, Nevada
Your stuff flies Al, I would agree the B-1 stuff is stought. Heck my 498" B1-BS makes just under 900HP.
Best Machine and Muscle Motors have done PSO deals and that stuff is real good.
For the money B-1's are hard to beat. <img src="/ubbthreads/images/graemlins/thumbs.gif" alt="" />
<img src="/ubbthreads/images/graemlins/beer.gif" alt="" />
Re: Some B1 Original pics......... [Re: Biginchmopar] #105643
12/08/11 09:14 PM
12/08/11 09:14 PM
PA.
"Little"John
"Little"John
PA.
You stuff flies Al, I would agree the B-1 stuff is stought. Heck my 498" B1-BS makes just under 900HP.
How fast and at what weight does that 900HP b1-BS run or is this another FANTASY dyno post?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Some B1 Original pics......... [Re: pittsburghracer] #105644
12/08/11 09:35 PM
12/08/11 09:35 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Yea
Id like to know too... Those BS heads are about like a Indy SR I thought?
